Re: Distributerless Ignition possiblity.. (working on it)
ok, i need some guidance here oh wise ones....
Is there any reason we can't clamp the wheel in place using the crank pulley? Would offsetting the belt 3/8" cause a problem/excessive rubbing? If not, this could be a viable way to clamp it.
Or, we could clamp it on the engine side and just use extended crank pulley bolts, and use nuts on the backside to hold the wheel on. the 3 ears could be machined down from 3/8" to say 1/8" so that the pulley doesn't sit as far away from the stock location.
thoughts?
Also, how big do the notches in the wheel need to be? how wide and how deep?
(note: i didn't spend a ton of time making this symmetric, just trying to get the overall design down, and then i'll make it symmetrical so its as balanced as possible. So please disregard any obvious non-symmetry on this draft)
thoughts?
