DM ?s
TYTILIDIE
METH HEAD
Ive been doing some logging and am not sure about a few things.
1. I thought that the stock MAP cant read over 14.7 PSI. My DM is reading 17 PSI.
2. How can I possibly be running that much boost.
3. I noticed when it gets into that much boost I get 9* of KR. But only in 3rd gear or over. Is this normal? I know the 9* is bad but is the KR at high speed normal? I also noticed that when I get these high boost readings, the trucks starts to feel sluggish.
4. At idle or slow speeds my STERMs are rich. My INJ DC spikes espacially at idle. IS this normal?
5. When I let off the throttle running the 1/4 mile distance, I get a DATA ERROR flash. Anyone seen this before?
Any help is appreciated. BTW, my truck is pretty much bone stock.
Mike
sy538
I think that I’ve read on here that above 14.7 the truck will try to guess how much boost there is.
What are you O2mv while at wot? While its knocking?
I would not got wot again until you figure out why its knocking so much.
93 TY 2185
Re: DM ?s
Mike
Email me your file and i'll take a look.
TYTILIDIE
METH HEAD
93 TY 2185 Posted: Mon Dec 13, 2004 8:59 am Post subject: Re: DM ?s
Mike
I can do that but I can only Email the spreadsheet cause I cant get DM on my PC for some reason.
O2mV are between 950 and 980 @WOT when knocking.
Mike
InvisiBill
You can't just copy the .uni file from your laptop?
If you can email it to me, I can host it for others to check out.
turbodig
Re: DM ?s
This is misrepresented quite often. The stock MAP has no such limitation.
The real limitation is that the stock MAP can't read any greater than 200
KPA Absolute. (Approximately 29 psi absolute)
At sea level, with dry air and normal temps, the normal absolute air
pressure is ~100 KPA. 200 KPA - 100 KPA gives you a range of 100
kpa , or an effective boost range of 0-14.7 psi.
At altitude, however, things change.
At ~5300 feet, "normal" atmospheric barometric pressure is 83.2 KPA.
200 - 83 gives you 117 KPA, or ~17 psi.
Varying levels of atmospheric pressure (just the daily fluctuations) can
cause a difference in how much range the MAP will have.
Not sure where you live, but I'm guessing it's somewhere with fairly high
altitude... or a really low barometer day. (Your DM baro reads 81.2)
Also, DM isn't always so accurate in how it represents boost. Part of the
blame for this can be placed on the ECM's code for determining what the
baro is... it's not always consistent. There is also some rounding that
takes place internally, which can also cause some scaling errors.
Yup. You'll be seeing greater MAT temps and more load in 3rd gear.
The sluggishness is partially the KR, partially the heat.
(Note your 160 + MAT temps)
The spikes are a bug... ignore 'em.
The high Integrator and BLM are consistent with high altitude operation.
Happens quite a bit. A lot of guys get even more data errors than that.
There's a whole discussion on DM data errors, a search should find that
for you.
Mike
Your boost is kinda all over the place... I'd check to see how free your
WG is moving. This kind of boost control is pretty typical of most 2 bar
chips... you might want to step up to a custom chip, or an external WG.
later,
Dig
'91 Sy - 11.83@114 | 20g , 9/11.
TYTILIDIE
METH HEAD
Thanks A lot for the input I really appreciate it. I am at high altitude as I live in Colorado Springs Colorado. Welp...guess its time to save for some toys.
Mike
TYTILIDIE
METH HEAD
Cant find anything that would really give all this knock. I was wondering though if it is possible that the injectors can cause a lot of knock. Just a thought. It seems as though they sound a bit louder these days at idle. I was also wondering where people move their knock sensor to when they relocate it.
Mike
SY2455
70's Veteran
If I can ask a question on this post, will a stock chip truck work with a 3-bar MAP or does it throw everything off as far as fueling goes???
sy538
High 900 O2mv is somewhat rich so your injectors are delivering enough fuel if that is what you are asking. 160 IAT is high, 130 is the highest I’ve seen on mine with a hotwired Johnson pump and rerouted lines. At the minimum hotwire your pump and make sure its running.
http://www.sytyarchives.com/howto/
has a few how to's on the IC
http://www.autoperformanceengineering.com/
has the johnson pumps
Edit
No you can not use a 3bar map with a stock chip.
This is just my theory so I could be wrong but I’m thinking the map sensor sends the computer a signal from 1 to 10 (just making up # for an example) so a 2 bar map sends 1 for 14.7 vacuum, 5 for 0 vacuum/ 0 boost, and 10 for 14.7 boost. Now put in a 3 bar and it will send 1 for 14.7 vacuum, 3.3 for 0vacuum / 0 boost, 6.6 for 14.7 boost, and 10 for 29.4 boost. I know you cant do it but that is just my guess as to why.
TYTILIDIE
METH HEAD
Funny you should mention the IC. I spent Friday tacking down someone who had a pump in stock. I finally found a guy who sold me a shurflo pump for $40. I installed it and immediately noticed a difference in my top end. My E.T.'s on DM went down 1/2 a second on average. My IAT's dropped to a high of 137. The IC is now cool to the touch unlike before. However, still getting 9* of retard. Could no cat cause this?
sy538
If you have a stock turbo then no cat will cause the overboosting you are having which could be causing the knock. You need a cat or a bigger turbo. So you replaced your IC pump and you IATs dropped 20-25* and this did not lower knock?
TYTILIDIE
METH HEAD
Nope knock stayed exactly where it was at. If you want me to post my new runs I can do it tomorrow but I left my laptop at my sisters house. My cats off cause when I did my motor last year I cut my exhaust off ( long strory ) and just clamped a muffler to the downpipe. Had it welded and had them make pipe to dump out the rear. I plan on having it re-done with cat and no muffler but just havent got around to doing it yet cause I can make up my mind of how I want it to get done.
Mike
