does ultimate chip use a g1 adapter??
supersports10
i have an ultimate chip for stock injectors, and i was wondering if they used a g1 adapter to hook to the ecm??
i am going code 59, i have the ostrich, datamaster, etc,,
i just dont want to buy a g1 if i already have one????? ;)
Re: does ultimate chip use a g1 adapter??
no, is a custom adaptor developed for ultimate. Although it might be able to be used, I would just suggest the $30 G1 which is known to work perfect with very little hassle.
supersports10
10-4 :tup: thats all i need to know,...thanks.
ZavzTy547
Senior Member
Isn't the ultimate very similiar to what Moates describes as a G3 adapter, which will allow you to select different bins? I was told by Craig Moates that its a plug and play with the Ostrich. I think Jeremy was playing with this setup but I'm not sure what the results was .
Tooky
Serious about performance
The ultimate is very similar in function to the Moates G3, but totally incompatible in every way. The Ultimate basically isn't compatible with anything Moates sells. It can't even run a burned Flash (29F040) chip.
turbodig
Ultimates can be converted to use a Moates adapter, if you have a moates G3 and want to control it with the ultimate control box.
Involves a good bit of rewiring, and moving stuff around on the chip itself.
ZavzTy547
Senior Member
Man, I knew it was to good to be true...
The ultimate has too many safety features for me to toss for a G1 and Ostrich, so I guess I have to revert to burning chips for now.
Is it possible to use code 59 bin to burn multiple bins to a ultimate chip?
Which leads to the next question, why is the (29F040) chip is not compatible with the ultimate and what chip are we using to reburn?
Yes code59 can be loaded up in the ultimate. Takes some work, and I am not an expert in that.
Best is to emulate until you get a bin you like, then make your different version for the ultimate. IMO.
mattw
Here is an idea.. Sell your ultimate for the $250 - $300 that you can still get for them and use the $ to buy moates hardware. The G3 will do the same thing as your ultimate and its a heck of a lot more supported.
-Matt
ZavzTy547
Senior Member
-Matt
Matt, I thought about selling the ultimate but their's a big feature that the Ultimate offers that I can't live without. "The knock light". It's really what kept my truck from self destructing all of these years. As soon as I see that light flicker, I was out of it and you can't react as quickly with datamaster....
Dig, you mentioned that the Ultimate controller could be compatible with the G3 with some rewiring. Would the knock light still be functional as well?
If compatible, could you ping privately on how much this would cost?
Also, is "Autotune" only compatible with code59 bin or can you use it to datalog any bin like a T3-22 bin from the Ultimate for example and burn a new chip using the autotune parameters...
Lastly, Since the 29f040 is not compatible with the Ultimate, were can I get these mysterious chips and can the Moates chip burner actually read and burn this mysterious Ultimate chip?
Thanks
Autotune only works with code59 due to some features we were able to add in the ALDL stream that make it possible. Really isn't possible easily on a stock bin.
Code59 will probably release a knock gauge output sometime in near future. The feature is actually done and working and gives you more than just a light but a real number. Still in beta testing though.
turbodig
It is. It involves rewiring, and remapping the chip a bit. $59 is a 32k bin, where the stock $58 is 16k. Not a drop-in situation.
They are... I've done a couple now. You just have to get the address mapping right.
A full-custom Ultimate, with each position tuned to your particular truck, is pretty much the best you could get in terms of a stock computer chip.
Problem is, you'd have to pay somebody a fair amount of $$ to do 16 individual tunes for you. At the very least, you'd have to do 4 or 5 unique tunes, with timing changes filling the other slots. This would still be kinda expensive, and time-consuming if done properly.
I'm not aware of any safety feature that an ultimate can do that you can't with an ostrich.
Don't want it to run? Take the ostrich with you when you leave. Or, load the ostrich up with a multichip bin and keep your ultimate box. The best of both worlds.
turbodig
There's nothing magic about the Ultimate's "knock light". You can wire any adapter to an LED or a door buzzer, or Mack truck air horn. Disco lights. Whatever.
Will do.
Autotune assumes the code59 ve table sizes, among other things. Could it be made to work with old code? Maybe. Are we gonna? Probably not soon. Many. many things to do project-wise that are further ahead in priority chain.
Thanks
I've never had any trouble with the ones I get from moates. What's important is that you're aware of the addressing differences when programming it, and set your bin up accordingly.
I think Paul did a 58 autotune, he sent me an email with a spreadsheet almost 2 years ago with it. I never did use it though.
Yes, well kindof. There is a couple spreedsheets where an "autotune" was done. I used these as research tools for our autotune.
The pitfall is the stock bin/aldl stream does not indicate data samples that have acceleration, power, or deceleration enrichment/enleanment active. Yes you can take data, do some math, averaging, and probably get some results but they may vary.
Code59 autotune looks at these data samples and removes those from the average. It does a lot more but that is the main advantage.
Also as most know code59 has a much larger VE table and in a lot of ways forced us to make autotune as dialing in 512 data points can be difficult without some tools. The stock code is ~80 data points or so and maybe half of those are actually used.
But as Dig said, i don't know of anything the ultimate does code59 does do. I can think of a lot of things code59 does though... :)
I am bias though.
