Re: E85 double pumper setup
Not if you want it to work right. The stock harness drops voltage too much as it is.
Run separate wires, and a bulkhead of some sort through the top of the sender. And a second relay for the second pump.
You'll also need a second pump, obviously, and a Y fitting to tie the two together.
You'll also need some sort of a strength support to the lid of the sender to keep the pumps from flopping around in there.
Walbro doesn't support their normal pumps in an e85 environment. They do have alcohol capable pumps, but they don't supply the volume of the 255s. That being said, a lot of guys run the regular Walbros just fine for long periods of time. You have to make sure to keep your system sealed so it doesn't draw water.
This is in addition to the bigger injectors (65 or bigger) and significant tuning you'll need to run it.
