E85 fuel
just a 6
R.I.P MyClone
Here in Sweden i can buy at the pump a fuel called E85, = a mix of 85% ethanol and 15% 95 octane fuel.
You can drive any regular car on it if you raise the fuelpressure or replace the injectors with bigger ones. Presently i'm driving my Mitsubishi Colt without any mods on a 50/50 mix of E85 and 98 octane with no problems.
The word is that E85 is equal to 104 octane, but let me explaine the different in octane between our country's.
I've heard that the European 98 is about the same as the US 94, because we messure the octane in different ratings. So 104 should be about 100 octane with US messurment.
I'm going to try to run my Syclone on 100% E85 when summer arrives, so my question is what are your thoughts about this fuel?
supersports10
:D i saw this fuel at a local mobil station this summer in janesville wi
i asked the cleark, and he handed me a sheet of paper that had a list of vheicles that could run on this stuff.
its no less than 85% ethanol, so im assuming that it has a higher rating than premium 93 that we have here
nallj92
careful...
careful...
careful, they say you can run it in ceraian vehicles and i would stick to what they say, back when i was working at a lube shop a car came in. the woman filled her car up with the e-85 stuff cause it was cheaper and she had a coupon. well the fuel pumps dont like it and the injectors dont either, needless to say we had to drain the entire fuel system and flush it. I know my friend ran it in his carb'ed motor 67 camaro mixed and it work ok for him but on a injected vehicle i'd do a bit more research before pumping it in.
nallj92
further information i found is that it can be used on vehicles as long as it is compatible with the things it comes in contact to. for carbed vehicles all is needed is new jetting to accept the differet fuel type, a bit of tuning and it should be good to go.
for injected engines, i found this link..
http://www.utep.edu/eafrl/pc98/evcpaper.htm
it basically says that if you want to run it you have to make sure your tank, lines and anything contacting the e-85 wont deteriorate. injectors need to be pushing more e85 to burn better at the different mixture needed.
so in conclusion, just a 6 is correct about the injectors and what not, mixing with normal gas is possible without modifications but with syty's or injected applications larger injectors and different tuning is needed but it can be done.
sorry for my quick uninformed answers before.
i might just do so testing on this with the snowblower this weekend and ask acouple professors at my engineering school to learn more about this
[/url]
supersports10
very informatave post,
so realisticaly, this should work on our trucks, if we bumpp up the fp 5-10 lbs, and use a ounce or 2 of marvel mystery oil, in the tank on every fillup, to keep the seals, and o-rings lubricated.
alcohol, dries out seals, and thats why they say it "eats non compatable componets"
turbodig
Every car built in the last 15 years is built with "alcohol compatible" rubber, plastics, etc. E85 won't eat anything up, or dry anything out any more than regular street gas.
As far as the oil, any concentration of oil in the gas that's small enough to not cause detonation is too small to do any good.
Regarding E85, the effective octane isn't really something that compares
really well to the R+M/2 rating in US gasolines. Literature quotes 100-106
normally, but that's hardly something you can bank on.
You have to recalibrate your fuel system for E85. You'll need roughly
1.5-1.8x the amount of fuel that you would with regular gasoline. Non calibrated vehicles will typically run on E-85, but you won't see really
good power until you tune for it. Driveability won't be much.
This would imply 50-60# injectors on a stock truck, more on a modified one.
It'd be interesting to see how an E85 Sy would perform, properly tuned.
I may try this once I get my Sy operational again...
Later,
Dig
'91 Sy - 11.94@114 |20g, 9/11
