Eagle Rod close to block
wildphil
I Love My Ty's
I have been assembling my engine. Started installing the pistons and rods and noticed that the rod bolts just barely miss the block. On #1 rod there isn't enough clearance to slide a piece of paper between the rod and the block. That's gotta be to close. Can anyone tell me what the clearance needs to be?
Am I going to have to pull the pistons and rods back out and clearance the block? Or can the rod bolts be ground a little to get the needed clearance?
nallj92
Re: Eagle Rod close to block
Depending on the core shift of the block, some may need block clearancing and some may not. When I did my engine, the drivers bank all needed clearancing while the pass bank only 1 needed clearancing. I would recommend block clearancing rather than the bolt heads due to the bolts being factored into the balance of the rotating assembly.
sy-2520
Same with me. Do not grind on the bolts. I had to take mine all the way back apart and clearance the block
Yep clearance block if needed. Grinding on the bolt will F up the balance of course if your Nate's original motor builder, they didn't think that was an issue either.
wildphil
I Love My Ty's
OK guys thanks. I was afraid that was what was needed. Guess it wont be to bad. The rings are filed to size and the bearing clearances are checked. So its just a matter of removing and then re-installing the stuff. After a little grinding and clean-up.
at least you know its right this time unlike some shops seem to do.
Aeroking
e.i.
mine was the same.
i mocked everything up 3 times before final assembly. :2cents:
Edit:
If you havent already, check the rod-bolt to pan clearnace. Also the pickup to pan clearance. And clay the valves. And check your pushrods for clearance around the heads. Check the rocker roller position on the valve stems. Put sealant on the head bolts so they dont leak coolant. Build the whole engine dry on the stand and rotate it and check all the clearances. Then tear it apart and do final assembly.
Throws
[...]If you havent already, check the rod-bolt to pan clearnace. Also the pickup to pan clearance.[...]
Make sure you use a oil pan gasket when you do this, especially for the pickup-to-pan.
-P
Syclone22
ARP rod bolt to block clearance must be at least
0.060 inch if not your block has to be grinded to
get this any machine shop can do this when installing
these rods with ARP bolts .
Ty 1885
I grinded the bolts on mine. It only took 1 gram off, will NOT affect your balance!
wildphil
I Love My Ty's
I went ahead and took it apart and ground the block. It wasn't to bad.
