Easiest way to lower battery?
Throws
Can;t seem to find what I'm looking for, a fairly easy/cheap way to drop the battery into the fender. Seems like everything is missing pictures or is linking to dead off-site links.
ATR kits are kinda what I'm looking for, but everything is out of production. 17 years old, I get it. I'd hate to think there's no new ideas, or even ways to get old ones. But if it's out there in .DXF it would help... or *something*.
-P
Fighting5thSVT
Re: Easiest way to lower battery?
If you decide to go with a smaller battery, my setup works great using a Braille no-weight battery in the stock location. Let me know if you would like some help
Ty 1885
-P
I dont have pics, however this is what i did.
Remove your front pass tire, remove your interfender , unbolt your battery tray, lower it about 4inches straitdown untill it sits on a small crossframe( you will need to trim the tray abit) drill 2 holes to secure it to the right side, 2 holes in the front, and get a 2 inch by about 12 inch flat piece of metal, bent it 90 degrees, bolt the bottom part to the lower bumper support, the upper part to the battery tray, then cut the front of the interfender a bit to fit back in, bolt it back in.
Remember that the battery trays NEW location is ABOVE the interfender!
You may need a longer NEG cable.
I did this 6 years ago, works great with ANY battery! It took me about 2 hours, its not hard! Total cost $15.00 (black paint, longer neg cable)
