Ecm for bench top tunning
cloneman315
I have gotten most of my tunning gear and I am playing around with some things,Has anyone took a ecm and powered it up on the bench so you can read to the ecm with a romulator etc etc,rather than being in the truck?
BigBadSmoosh
Re: Ecm for bench top tunning
yes, dig has a setup and there are various desktop setups available from some vendors.
mattw
I haven't done it with a 749 but I did do it with a GM ECM when I was setting it up to control an 80E..
turbodig
Yup.
Unless you were messing with code or trying to figure out how things work, I'm not sure what value it would have....
ziembic
If you just want to look at the code that is on the ECM, wouldn't you just download it with Tuner Pro and then access it via Tuner pro? Short of giving it inputs like a running motor, what can't you do with tuner pro that you can do with the actual ECM?
cloneman315
I am just starting to get into this a bit heavier,isnt there some things in the program etc that need to see a ecm?>
ziembic
Once you have a bin to start with the you are good to go. But that being said I am no expert. My truck ran 59 before it cooked the head gasket. I started with one of the starter bins from the 59 forum and went to town. But I was able to do everything at my desk in the house. You can tune on the fly with an emulator, but you don't have to.
turbodig
Well, there's a bit more to than that. What you're talking about is that data the code looks at for fuel, timing, etc.
When you start looking at the code, you can change waht the ECM *does*. Like extend the RPM range. Or add another o2 sensor. Or control a transmission....
The code we use is really very deep.... there are aspects of the code that most people here never use or see.
Which is ok, because most people really don't need to. The basics do just fine.
I've been tuning and developing code for 16 years+, and I can't even begin to say I know it well.
turbodig
dig is it as easy as just powering up some wires and grounds?
The ecm will power up with a minimum of stuff... the +batt and ign leads will allow you to connect.
You'll get some codes until you hook up the basic sensors hooked up (map, tps, etc), but it'll work.
If you want to have something to hook up, check out the jimstim board from the megasquirt guys. It'll simulate a lot of our signals.
I have a board designed to simulate all our signals, but I don't know of anybody making those any more.
cloneman315
would I have to search and find one? jimstim board ?what is the board you have?
turbodig
I've got an old Bob Ward one... waaaaay back from early internet days, early 90s.
Search the megasquirt boards for jimstim....
cloneman315
found them ,looks like maybe you have to put some of it together etc.So this boars just simulates data?
