ECU on a custom application
PhantomGTZ
I apologize ahead of time on my lack of knowledge, I wanna learn as much as I can about the ECU used in the Turbo sunbird/ syclone/typhoon.
I'm assembling a monster of Oldsmobile Quad 4 turbo. (Garrett GT30R, all internals forged balanced, and cryotreated)
In 1988 when the Quad 4 debuted, it came with the same ECU that you guys use. This led me to a few conclusions:
1. It will work with a distributerless ignition
2. It would allow the quad 4 to use 2 bar and 3 bar map sensors
The snag I'm curious about right now is that the 1988 quads had that 15 degree offset on the reluctor wheel on the crank position sensor.
How would go about adapting this ECU to a turbocharged quad 4? GM already did it with their pace car that year but it never made it into production.
Any help would be appreciated. Looking at some of your posts, you guys definately know your stuff.
turbodig
Re: ECU on a custom application
DIS will work. If you look at how the Quad4 and 3.1 V6 did DIS, the
majority of the brains for the ignition are in the ignition module itself.
It takes the pulses from the reluctor and feeds the ECM a REF signal
from there. The ECM simply feeds back EST.
The 15 degree thing won't be a big issue, although you may have to
alter the base reference angle slightly to get it to fire
I'd start with the sunbird calibration and work forward from there. It
was a turbo 4-cyl to start with.
You will have to pretty much re-pin the ECM wiring harness at the ECM
end to get it to line up with the sunbird pinout.
Later,
Dig
