EGT & A/F with meth injection
djwaggoner
I've searched but didn't find what I need to know: what is a desireable EGT with Razor's meth inj? And, what A/F ratio is desirable ?
Up around 12 psi my A/F goes to 10.9:1 & has been 10.5:1 @ 16psi. My question is; what # is optimal w/ meth inj? I'm currently @ the recommended 12:00 position on the controller. I'm running a stock eng/turbo/IC and a 3" dp, cat & exhaust.
Secondly; is the meth causing my EGT to drop to 450 - 480? What is optimal EGT w/ meth inj?
Thoughts, ideas & opinions most welcome.
Thanks guys
Oops! forgot 3bar Ultimate - at T2 17....tho' DM shows target boost at 20, I've never seen it above 16.1 & the WG duty cycle is 68%......WTF is that!?
It's just a six
Super Member
Re: EGT & A/F with meth injection
You should be able to run about 20 or even more psi so you can turn up the boost.
Off hand I forgot what temps for the EGT,( guys, anyone ?) but 10.5-11.0 A/F ratio range for the meth even as rich as 10.0 is OK.
My Sy has seen as rich as 9.8 A/F ratio & it still ran great!
The A/F ratio is what works good for me on T3 setting & 24 PSI on 91 octane.
Watch for knock! :tup:
djwaggoner
Watching knock on DM - only had a count of 7 for the whole run & <4* retard at any point.
I haven't ventured into T3 yet. I wanted to make sure that the cool EGT & super rich A/F wasn't forboding unpleasant noises. I'm seeing 800+* at cruise and it dropped to <500* at boost - I was _hoping_ that it was due to the meth... Thanks for the reassurance.
I don't understand why my wastegate is opening at 16psi when the target boost is 20???
How are you getting 24psi? Stock turbo & WG? ECM or external boost controller?
Thanks again!
djwaggoner
DM shows like 70% duty cycle for the WG actuator - it's opening the WG, but w/ a target boost of 20psi. That's the part I don't understand....?
As long as the EGT drop isn't pathological - I'm happy w/ that.
turbodig
This is how the boost system operates. After the inital MAP threshold is reached, the WG initializes to whatever DC the table is set to, and then attempts to control via closed loop boost control.
In other words, regardless of what the desired boost is, it'll always make an initial guess at WG opening, and start correcting from there. When it reaches the desired boost, it stops correcting.
djwaggoner
Thanks for the info - I would _never_ have expected the ECM to open the wastegate when the 'target boost' hasn't been reached. Tho' Ultimate at T2-17 may override the target boost?
If I want to get to, say 20 psi, I'll need an EBC then?
I know the turbo is capable because I hit 25 or so for a split-second once when the hose to the boost solenoid blew off.
