EGT logging
leroy
I've been thinking about hooking my egt thermocouple to the ecm. I can use the stock O2 sensor input, since I am running open loop with a wideband. It would be interesting to plot egt's v. AFR.
Anyone see why this wouldn't work?
Jim
Falco
Jim,
That's something I've been thinking for a while now. What kinda EGT and probe are you using?
Later,
leroy
I have a K type thermocouple threaded into the exhaust manifold #1 cylinder. I would have to get the temperature v. millivolt specs.
Jim
leroy
I found a chart from Westach, where I purchased my gauge, but the values look similar.
Jim
turbodig
Re: EGT logging
Jim
Depends on the scaling of your thermocouple amp... if it's in the 0-1v range,
you're in business.
Add a lookup table like the AFR code has, and you could read it out as
EGR = temp/100, or something like that.
It'd really, really be cool if we could have a couple (like 4 or so) custom-
definable fields in DataMaster. EGT, maybe cyl pressure... the mind boggles.
Dig
sytyguy
Moderated User
Re: EGT logging
turbodig said:
It'd really, really be cool if we could have a couple (like 4 or so) custom-definable fields in DataMaster. EGT, maybe cyl pressure... the mind boggles.Dig
I believe Mark Mansur's software is supposed to implement something of this nature. He's catering it around Moates' new AP1 AutoProm adapter which contains three 0-5v A/D inputs on his board.
Dunno if this is any help/insight/light-at-the-end-of-the-tunnel or not, but here's the link - http://www.moates.net/autoprom/apmanual.htm
Hood
turbodig
Re: EGT logging
Hood
Cool.... loads of car-geek goodness.
It does let you do custom defs, and it will let you scale it however you want.
Works just fine with an ordinary DM cable also.
This will be a very interesting product as it matures... has the potential
of FAST-style tuning ease, with the stock ECM.
turbodig
Can somebody with a DM cable and a downloaded copy of Tunerpro give something a try for me? I've been working with Mark on a ALDL def file,
and it looks pretty good so far.
I've got it working on the bench here, but #689 is in storage, and I'd like
to try it on something live.
E-mail me privately if you're willing to help.
turbodig<nospamatsign>yahoo<dot>com
Thanks,
Dig
Ian Turgeon
Cascading Inspiration
would be willing to help but I need to get ahold of a dm cable.... any suggestion on where to buy or some instructions to make?
turbodig
Akmcables.com will sell you a cable ready-made.
If you're cheap like me, you can go the DIY route....
http://www.andywhittaker.com/ecu/aldl_hardware_cont.htm
The 2-transistor interface should be buildable for less than $10.
(and waaaay less, if you know where to shop... like less than $2)
Think about that... a totally functional scan tool can be had for $2,
provided you already have a windows laptop.
Haven't tested a 2-wire with tunerpro, but it should work. I used the AKM
that I got with DM.
Later,
Dig
