Electronic prob
BadTy
Hi guys
Take an electronic prob on a customers Ty. On WOT it takes fluctuation of RPM. If i accelere slowly (not WOT) it runs normally. Stock chip. replaced already: o2 sensor, spark cables + CR42TS spark plugs, cap and rotor, no DTC`s.
Some months ago i replaced the engine. All sensors and filters new.
Someone can help me?
How I can upload a datamster file?
turbodig
Re: Electronic prob
BadTy said:
Hi guys
Wastegate overboost. Check for free movement of WG rod/arm.
Also make sure it's not activating the rev limiter on the stock chip. ~4700 RPM.
What brand of spark cables did you use?
BadTy
Re: Electronic prob
I use the OE plus performance cables from Standard 7mm,
Datamaster shows the boost target on 16 psi. Max boost acc. to DM is 15.5 psi. But the aux boost gadget displays on WOT shortly over 20 PSI.
If it possible i like to send you the DM- file by email.
Please let me know
turbodig
Re: Electronic prob
Please let me know
Sure .
Turbodig @ yahoo.com
Tooky
Serious about performance
Re: Electronic prob
Did you gap the CR42TS at .035" or tighter (as tight as .025")? Too big a gap will blow the spark out and cause tach flutter and engine stutter.
