Ive been having some issues lately. A coue weeks ago, the engine got a bit hot when I was going up the mountains with the A/C on. I saw smoke coming out the tail pipe and the car bogged down quite a bit. Pulled over and let her cool down, then drove the rest of the way with the A/C off. Truck ran just fine after that. Replaced thermo stat, water pump, radiator cap, and flushed everything out. Been great ever since.
Last week I did an oil change with 5w30 this time and it took a couple days but it started smoking quite a bit out the tail pipe. Drained some oil out and added 1 quart of Lucas oil stop leak stuff and topped it off with 10w30. Smoking cut down to practically nothing now. Every once and awhile it will smoke when accelerating. The problem I have the most is that the idle is above 1000 rpms in park and nuetral, and 800ish in reverse and drive but engine shakes quite a bit. It will not smoke in gear while stopped, but put it into neutral and it will smoke, put it back into gear and it stops. Gas mileage sucks now too, not that I'm expecting 20 plus mpgs. Any idea what's wrong? I can't find any vacuum leaks, although I'm going to change out all vacuum lines tomorrow just to be safe. Truck also smells a bit rich too, I'll be installing my wideband tomorrow as well to verify.
I do have a brand new O2 sensor, spark plugs/wires, ignition cap/rotor, and ignition coil installed about 2-3 weeks ago.
