Engine problem , would appreciate your input
Re: Engine problem , would appreciate your input
the kit sounds like a plan ! I appreciate that...
I want to check the waste gate and remove the c clip holding the rod in place to see if it has the proper movement , question is. How hard is it to get to the waste gate ?
is it visible and easy to get to ?
You will need to remove the inner fender to access the wastegate actuator rod clip.
the baPhoon
Just do things right and replace all the vac lines. A quick fix is just asking for the truck to have an extended vacation on Jack stands. If you dot have datamaster or another form of datalogger I would suggest getting one ASAP.
NO MORE TEST RUNS. If you don't know the specific problem you run the risk of making a simple fix a new motor build.
defc0n
I know what you mean...
Thank god the motor idles fine and does not smoke , it's mainly not boosting at all right now.
ZavzTy547
Senior Member
Sounds like your intercooler pipe/hose may be leaking. They blow off all the time....
