Re: Engine problem , would appreciate your input
You will need to remove the inner fender to access the wastegate actuator rod clip.
the kit sounds like a plan ! I appreciate that...
I want to check the waste gate and remove the c clip holding the rod in place to see if it has the proper movement , question is. How hard is it to get to the waste gate ?
is it visible and easy to get to ?
