TurboManiacal
Hey All,
Gonna try to help Bezerk (Rene) out with his engine woes. He'd really like an engine w/ warranty but location / price is prohibitive in this case.
I remember Myclone did an excellent write up several months ago on what his dream builds would be in
I tried the search but it's down at the moment.
Here's what we're up against and have to work with:
Screening criteria:
It's been expressed that we should keep the cost down under $1500 for parts.
The beauty of the situation is Rene owns his own Machine shop. We will need all the specs and machining instructions.
I'm hoping for a step by step comprehensive listing of things that need to be considered when building up an engine.
Maybe with the proper inputs...this could be a vault posting.
- Low Budget
- Medium Budget
- All out Build
- 1 Block that had no compression in one piston but maybe bored out to the max (.060 over already)
- 1 Block that spun the crank and may not be a viable rebuild candidate.
- My old block. This engine blew a head gasket and was driven 25 miles. Compression was 50psi in Cyl #1 and was knocking real good when it was parked for my Kosovo trip. When I pulled it out I checked the #1 spark plug and the tip was destroyed. Lots of metal shavings in the oil. I'm thinking this is our most viable rebuild candidate.
Screening criteria:
