Engine Rebuild / Recipe
bezerk
So what should we be doing with the balancing?
Going with an $80 (approx) flexplate?
damper $150 (approx)
Eagle H-Beam $365
SpeedproPisons $310 (approx)
bring it to a balancer in the US? that would cost......?
Sigo?
about the heads, what is included? springs valves and rockers?
And did you purchesed the heads already, if so please give me some more information.
and let's order a MSD ignition disurbitor, coil and wires (approx $300)
To bad i only have a Summit mag. so alot of articles i can''t find, checked i though.
i hope you guys have great discounts, otherwise it''s a real money pit!!
more than i would believe
Rene
TurboManiacal
Eagle H-Beam $365
bring it to a balancer in the US? that would cost: $300
Sigo?
about the heads: Two Options: $800 / $1300 Both include 2.05/1.60 Valves. The more expensive ones are fully ported / polished. Rockers are +$300 for both heads.
And did you purchesed the heads already, if so please give me some more information. Not yet, waiting for your "go"
and let's order a MSD ignition disurbitor, coil and wires (approx $300) Will let you know price
To bad i only have a Summit mag. so alot of articles i can''t find, checked i though. Best thing going right now
more than i would believe Working on it.
Rene
myclone
canadian said:
another topic about the head bolts. looks like the v8 kit isn't much different than the v6 kit
http://www.syty.net/phpBB2/viewtopic.php?t=24788&highlight=arp+v6
The stock blocks have through holes into the water jacket for the head bolts so IMO the V8 bolts being .020 longer arent an issue. If they were blind holes (bow tie?) and/or the block was decked massive amounts then I would see the need for V6 specific bolts.
Methuselah said:
As far as I am aware, you are not able to order 4.3 v6 rod bearings from Jegs or Summit (dont know about Northern Auto), as they are different from both small and large journal 350 bearings. So unless your engine builder supplies them, you'll need to take a trip to <gasp> Autozone, which stocks Clevittes for our application..
You are correct. The 4.3 rod journals are larger than the SBC so they require a specific sized bearing. Most any chain store will have them in stock but I dunno about over seas :-? . The main bearings are readily available as they are the exact same part used in the large journal SBC with one piece rear main seal (1986 and up).
bezerk
Sigo?
This includes the lower intake i geuss?
So i have read that porting doesn''t increase the flowing numbers alot.
and the cheaper onces, (if they include valves they also must include springs i geuss) are rebuild/new.
So no head work has to be done to those?
Valve covers???
are there good Gasgets and oil-seals set avalible, or should i go orig. GM?
i really hate to ask so much questions, :oops:
TurboManiacal
bezerk said:
This includes the lower intake i guess?The Intakes that we will need have just finished being portmatched & welded for vortecs. That's about $500+ Core
So i have read that porting doesn''t increase the flowing numbers alot.Moe importantly here, Vortecs in stock form as I understand it, and have seen with mine eyes, are much less prone to detonation. For the build we're going for, we won't need monster flow numbers.
and the cheaper onces, (if they include valves they also must include springs i geuss) are rebuild/new. The include everything but the rockers. Rockers = +$300
So no head work has to be done to those? Correct
Valve covers??? Included
We'll get all the right gaskets ahead of time. Head gasket will come with the Intakes.
bezerk
:roll: maybe i completly missunderstanding something here.
But: Vortecheads, + lowerintake welded/ported +covers +gasgets for $800 +$300 for rockers
or $500 +$800 +$300
that''s a whole different story.
as i read it, it makes me think the last.
but vortec heads are only $200????
maybe $300 with drilling and tapping.
Going on a little holliday tommorow.
Will be back on monday
So good luck with the shopping list, and make me happy :angel:
but don''t scare me with the bill.
Maybe, if somebody brings the stuff to a machine shop, they can measure the pistons, give them to me,and i bring the measurement to my machine shop to bore up my block.
So when Sigo arrives (with parts afcourse)we can put the engine together, and he can get dirty hands???
and aslo install the walbro!!
Rene
bezerk
oh fuck no. I ain't doing another walbro on a Typhoon. Syclone, yes...Typhoon no. You're on your own buddy.
Damned..... So i''ve to do the Dirty work myselve.
Maybe you could order H-beams from raceprovemotors? $365 a set.
Also the pistons maybe, crankshaft perhaps with damper and flexplate?
and let them do balance?
just a suggestion.
But................
please tell me the plan,prices.
Can''t wait.
Rene
So holliday has started, so no more BS from me this weekend!!!!! :wink:
bezerk
I believe i''am gonna do the 4bolt maincap.
it would propperbly cost me 350€ extra.
So i don''t think i''am gonna save at that one
nightdiver
I used the millodons in this engine . Read the instructions carefully...you have to do some cutting , then istall and lineup the mains and then cut the inside
Frank
Great topic. A lot of useful information has been provided.
I vote to move this topic to Tech Article section.
93ty475
walbro on a ty is a piece of cake :lol:
bezerk
What is the proper compression ratio? Is it affected by larger turbo or other mods? Jim
1:8.5 (correct?)
is the walbro right under the thing in the back, where you can hook things up to ??
maybe i should cut some metal out, to make it easier for the next time?
and please tell me the clearence between body, and tank, don''t want to cut true the tank
[/quote]
TURBO TY
hey bezerk, f you want to save some money you could go with the gm 2 bolt billet caps with arp main studs. hope that hlps ya :wink:
bezerk
how much horsepower would be safe if i would install those billets 2bolts??
it''s going to cost me $$ annyway.
:lol:
