Engine Rebuild / Recipe
bigtime
Sy-Ty Builder
TURBO TY said:
hey bezerk, f you want to save some money you could go with the gm 2 bolt billet caps with arp main studs. hope that hlps ya :wink:
It would still need to be alighn bored, you would only save the time
to put it in a milling machine and drill 4 holes.
bezerk
just bolt in the 4 boltmain caps with the 2 orig. bolts, centermark the 2 other remaining holes, drill and tap?
that''s the whole case???
tell me it is!!
Rene
bigtime
Sy-Ty Builder
tell me it is!!
Rene
That pretty much covers it. I do mine in a milling machine for accuracy
although I am sure some people have done them by hand. The catch is, you
then have to take it to someone with a alighn 'bore' tool NOT a alighn
'hone'. As long as you have a shop that can do this your good. You can
even buy 4 bolt sbc conversion caps from eagle for around $75.00. Just
throw the extra one to the side.
bezerk
So what''s the deal with the accuracy? maybe i''am compleet of the line, but if i alighn with the 2 origanal bolts, just drill and tap like i explained, wat would be the problem if the bore (center of hole at bottem end of hole and above of hole) is miss alighned 2 degrees.
we just torque the 2 origenal bolts, than the 2 drilled onces, so there should be no problem or missaligned maincaps.
don''t want to disagree or annything, but i don''t understand why people bring it to a millingstore, if they have a handdrillingmachine at home.
but please tell me if i''am wrong.
Rene
bigtime
Sy-Ty Builder
No problem, I'm just picky! I believe in doing everything as
perfect as I can because so many thing can go wrong. If you
would make a drill insert you could drill right through the cap
using the cap as a guide. Milidon caps come with the insert
but do cost over $200.00.
nightdiver
Millodons come taller and smaller in the inside.
You have to mill the face that comes in contact with the block so the outer "lips"will have some specified clearence.
They are smaller inside so you do the job by your standars(crank)
If it is an angled cap you cant do it by hand...if the hole isnt right angled the cap will distort
You can use gm caps that doens need that much to do but i dont know if it comes with straight bolts to make your drilling easier
sytyguy
Moderated User
Ryan, Rene........sorry I'm so late getting in on this. I really do apologize.
Anywho, here's what I have to offer.....digest as you would:
Pistons
- TRW - L2441F30 - $39.99
- SRP - Not Available
Rings
- Total Seal - Not Available
- Perfect Circle (Moly) - 40564030 - $49.99 set
Rods
- Eagle - CRS570063D - $349.99 set
Camshaft
- Comp 094128 - $229.99
- Comp 094228 - $229.99
Timing Set
- Cloyes - C3056K - $39.99
Pushrods
- Comp Hi Energy - 7808-12 - $29.99
- Manley 1 piece - 25733-16 - $99.99 (available in 16 only)
Lifters
- Comp Hi Energy - 850-12 - $139.99
- Comp Pro Magnum - 875-12 - $149.99
Rockers
- Comp - Stamped Steel SA 1.6 - 1416-12 - $139.99
- Comp - Full Aluminum SA 1.6 - 1318-12 - $215.99
Valve Springs
- Pioneer - LT1 Springs - 943 - $1.49 each
- Pioneer - LT1 Spring Kit - $49.99
- Comp - LS1 Conical Valve Springs - 26918-12 - $129.99
LS1 Retainers
- Comp - Titanium (for use with above springs) - 772-16 - $169.99
Rocker Studs
- Crane - 99148-2 - $17.99 pair (10mm-1.5 to 3/8-24 screw in stud)
Poly Locks
- Comp - 4601-16 - $49.99
Flexplate
- TCI - 399773 - $99.99
Main Caps
- Milodon - 11160 - $229.99
Head Studs
- ARP - 233-4001 - $99.99
Head Bolts
- ARP - 233-3701 - $119.99
Main Studs
- ARP - 233-5601 - $55.99
Oil Pump Stud
- ARP - 230-7001 - $4.99
Main Bearings
- Clevite - MS1454P - $23.99 set (same price for undersize)
Rod Bearings
- Clevite - CB1358P - $25.99 set (same price for undersize)
Cam Bearings
- Clevite - SH1351S - $19.99 set
Gaskets
- Victor -Head Set - HS5855 - $149.99
- Victor - Timing Set - JV1041 - $10.99
- Victor - Oil Pan Set - OS32485 - $29.99
- Victor - Rear Main Seal - JV1634 - $19.99
- Felpro - Vortec Intake Gaskets - 1203 - $19.99
I'm sure there's a ton of stuff I missed, so if you need me to price anything, post away.
Ryan, compile what all ya'll need and lemme know. I'll talk to ya soon.
Hood
TurboManiacal
Rene,
Ball is in your court:
+$300 Crank Treatment
+$500 Intakes
+$300 Balancing of Piston stuff
+$800 Vortecs
$1900
+All the $ added up from above
= ~$XXXX
So what do you want to do?
TurboManiacal
sytyguy said:
Pistons
Rings
Rods
Camshaft
$229.99
Timing Set
Pushrods
Lifters
Rockers
Valve Springs
LS1 Retainers
Rocker Studs
Poly Locks
Flexplate
Main Caps
Head Studs
Head Bolts
Main Studs
Oil Pump Stud
Main Bearings
Rod Bearings
Cam Bearings
Gaskets
Took out what I knew to be not necessary
TurboManiacal
nightdiver said:
Till you get the answer pack my AC compessors :p :p :p
Ask me about my personal parts that I ordered from the same guy that I need to make my truck run...(not just make me comfy in Greek Heat!)
bezerk
question:
how about the harmonic damper? doesn''t the balancer need one?
The TRW-pistons are good? comparing to speedpro and JE?
and how about the rings, comparing to child and alber or somethng simelair?
wich camshaft is best suited for the vortecs?
Sigo: votecs came with springs and valves, so i could skip that, also with gasgets??
what about oil-cooler? should i go for an external cooler, or new radiator?
MSD ignition, (coil +disurbitor)
really Tired, will calculate tomorrow,
Hood, don''t have to appoligize, i really apriciate the thing you are doing!
it''s just a hobby!, really expensive one though.
Rene
TurboManiacal
Pistons
Rings
Rods
Camshaft
Timing Set
Pushrods
Lifters
Rockers
Rocker Studs
Flexplate
Main Caps
Head Bolts
Oil Pump Stud
Main Bearings
Rod Bearings
Cam Bearings
Gaskets
Head Gasket $150
Freeze Plug kit $6
Hood
Whooo Hoo! finally talked to Hood. Parts to follow!
Vaders Sy
Kinda of off the topic since you guys are talking about rebuilding your motors but who offers built motors for the Sy/Ty's besides RPM?
TURBO TY
hey bezerk, i would go with SRP pistons. they are made by JE and are not that exspensive. i think mike lee sells them for $365.00. the TRW/Speedpro pistons are a little heavier and will cost a little more when you go to have them balanced. as far as the 4bolt main conversion goes, it is going to run you alot more money and i think it is not needed for your app. i think the two bolt billet caps are a better choice and you could save yourself a couple of bucks. yeah you would have to have the block align bored but that does not cost as much as taking the block to someone and having them drill it for the caps. i would not try to drill the block myself. i think that should be done by someone who has the proper equipment and knowledge. when i talked to the machine shop around here, the machinist said it was goin to be $300.00 to $350.00 just to drill the block and fit the 4bolt mains, not including the price of the 4bolt main caps.hope that helps
TurboManiacal
The TRW's are $240 ($39.99x6)
$300 w/ Waller
as far as the 4bolt main conversion goes, it is going to run you alot more money and i think it is not needed for your app. I think the two bolt billet caps are a better choice and you could save yourself a couple of bucks. yeah you would have to have the block align bored but that does not cost as much as taking the block to someone and having them drill it for the caps. i would not try to drill the block myself. i think that should be done by someone who has the proper equipment and knowledge. when i talked to the machine shop around here, the machinist said it was goin to be $300.00 to $350.00 just to drill the block and fit the 4bolt mains, not including the price of the 4bolt main caps.hope that helps
Rene's owns a full service Machine Shop that focuses on Tractor Repair. In this instance, it is a toss up but I think Rene wants to build this motor to last and have the peace of mind.
TurboManiacal
sytyguy said:
Pistons - TRW - L2441F30 - $39.99 ($239.94)
Rings - Perfect Circle (Moly) - 40564030 - $49.99 set
Rods - Eagle - CRS570063D - $349.99 set
Camshaft - Comp 094128 - $229.99
Timing Set - Cloyes - C3056K - $39.99
Pushrods - Manley 1 piece - 25733-16 - $99.99 (available in 16 only)
Lifters - Comp Pro Magnum - 875-12 - $149.99
Rockers - Comp - Stamped Steel SA 1.6 - 1416-12 - $139.99 (1299.87)
Rocker Studs - Crane - 99148-2 - $17.99 pair (10mm-1.5 to 3/8-24 screw in stud)
Flexplate - TCI - 399773 - $99.99
Main Caps - Milodon - 11160 - $229.99
Head Bolts - ARP - 233-3701 - $119.99
Oil Pump Stud - ARP - 230-7001 - $4.99
Main Bearings - Clevite - MS1454P - $23.99 set (same price for undersize)
Rod Bearings - Clevite - CB1358P - $25.99 set (same price for undersize)
Cam Bearings - Clevite - SH1351S - $19.99 set
Gaskets
- Head Gasket $150
Freeze Plug kit $6
= $2,095.74 (Approximately)
+$300 Crank Treatment (Core)
+$500 Intakes (Core)
+$300 Balancing of Pistons w/ Crank
+$800 Vortecs
=$3995.74
I know your heart just went into attack...but let me show you something... /James Carey from the 90's Show "In Living Colour"
http://www.tobefast.com/sytyengines.htm
Super Motor
Enough to get you into the 10's 1/4 Mile.... We start with a selected block. Then Machine it for 4-bolt splaid caps, put in TRW Pistons your choice of cam depending on engine management used, Eagle rods, Crank Shotpenned and Nitrited, Total seal rings, Then we top it off with our famous stage two Vortec Heads. These Babies flow the Big Numbers for power on top with out sacrificing driveability and low end power. Everything is balanced, blueprinted and racepreped with secrets learned over the years. We also Port-Polish and Refinish your Sy or Ty Intakes as part of the Deal.
$8500.00 Plus Shipping and Handling
His heads will flow more than yours...but otherwise that's the same build / motor right there.
Thoughts?
bezerk
after my own calculation i also went to that amount aprox 4000
And i also checked that engine out, Are you gonna do a port and polish on my upper intake??? :lol:
Sounds good, but throw me in a oilpump also.
+ waterpump gasgets, and don''t forget about my steeringpump pulley,
otherwise it would be a nasty testdrive.
please prices on pulley, oilpump approx $50.
and some rings fot the injectors! stock injectors.
sytyguy
Moderated User
Water pump gaskets will come with the gasket set, the oil pump will be around $19, and I'll throw in some injector O-Rings if they don't come with the kit (can't remember if they do or not off the top of my head). Will hafta check a price on the PS pump pulley. Never had to buy/sell one.
Michael
