Engine tiedown ?
I am looking into doing this mod. I've seen people using the metal chain types and also the nylon ratchet types. I have read that the metal ones may cause false knock, so I am leaning towards a nylon ratchet strap. I'm just wondering what is the best one to get and where to get them. I did a search but could'nt find much info. on them TIA guys!
nallj92
Re: Engine tiedown ?
I can set you up with my tiedown but using a strap in place of the chain also...........
TxSy1430
make your own for less than 10 bucks...i made the metal one myself with a turn buckle and chain for less than $10 from The Home Depot...
TYTILIDIE
METH HEAD
Not sure how the updated model is I am not a fan of the open end eyelet. Reason why is because I have pulled one apart. Even the closed ends I have broken in half. I hear great things about Nalj's kit though, I wouldn't worry. Plus, I have an odd truck that breaks all kinds of weird things:lol: I will say however, steer far clear of ratchet straps. I have snapped plenty of those as well. Doesn't get much better than the chain, even those I stretch pretty good:lol:
13Pelle
I have the tie down that nallj92 sells on here and have no complaints of any kind. Good price, looks great and easy install. Win win as far as I'm concerned. :tup:
Fighting5thSVT
x2
It was a breeze to install and fits well. To me, it's not worth saving a few $$ and going through the trouble of trying to make your own. Just buy it, install it and be done with it. Simple:tup:
Although, I did buy the chrome version--now I feel compelled to buy a chromed alternator to match!
Matt
x2
X3 :tup:
mcskibadee1
I know, I would buy one in a heartbeat but the thread says he is out of them. I saw one come up for sale but was too late. If anyone has an extra strap let me know!!!
mcskibadee1
I was wondering if anyone had any pictures of their engine straps? I am talking about the ratchet type that are nylon straps.I have heard mixed reviews about these, it seems like if you have a good strap that can hold it should be fine.I just want to know if there is any thing you have to fabricate to get this to work or is it just hook it and ratchet it and you are done. I want to know where the points are that you attach it to the body and then to the engine?
SY2932
Administrator
Here's the one that I have been running for about ten years now:
"DIY tie down, NO drilling required. Bolt is a 10.9 cut down and rethreaded."
The other end of the turnbuckle hooks into a hole that is already in the frame.
nallj92's is the best way to go about. I plan to go to solid mounts in the future so that I won't need one anymore...
mcskibadee1
so I just bought a engine tiedown from a fellow member and I was wondering if anyone has a pic of where you attached the hook to the frame? I cant seem to find where to hook it to.
Fighting5thSVT
You have to drill a hole for it. I will post a pic later on tonight if needed....
mcskibadee1
really??? I thought people said their was a hole there already for it but I might be mistaken. I have a 1992 Typhoon, does that make a difference?
Fighting5thSVT
Here is a shot (without lifting up the truck) of where mine is. That's where the instructions recommended. Worked out well!
[/IMG]
SYO237
SyTy Registry
Drilling a new hole is easy. The frame cuts like a hot knife through warm butter with a good drill bit. Just make sure you drill SMALLER than the diameter of the bolt so you can thread it in.
mcskibadee1
So, I am going to install my tie down in my typhoon and I noticed that it will go straight through the two hoses that come from the engine to the oil filter. Is this normal? It seems like that is teh only spot that it will fit to be straight and lined up so it isnt pulling one way or the other.
