ESC module power
Aeroking
e.i.
I am re-arranging my gauges, and want to add a GN knock gauge for visual.
I've been running my FAST without a knock sensor. I left the stock Syty one in the block, and this weekend wired it to a TBI ESC module. I'm not getting a knock signal to the ECU. ????
I powered it from a switch 12V source. I remember reading that the knock gauge needs to be powered from a switched 12V that goes off while cranking. I'm wondering if the ESC module needs a similar power source. I have good power, ground, and signal at the module. I'm wondering if 12V power while cranking the engine is buzzing the module.
any ideas?
Aeroking
e.i.
Re: ESC module power
Bump
tested everything. good 12V power, good ground, the sensor signal wire is fine. But the knock sensor isnt giving a AC voltage when i ping the block.
The sensor worked prior to installing the new harness. I'm going to replace the sensor and see if that fixes it.
Anyone running a standalone ECU, what sensor/module combo do you run. I have the Syty sensor with the TBI module. I would assume since both are 4.3, the module should produce a fairly accurate output, using the SyTy sensor.
ed hess
race or get outta the way
dont know how much this will help you but I was using the MSD knock indicator. To trigger the unit I was using a buick knock sensor module. YOu will have to hunt for the schematic but I just wired the msd to the buick esc module following the schematic. Was a no brainer and worked fine. Wont be using it anymore as when harry anderson tunes the thing I dont see any knock anyways... lol
ED
Aeroking
e.i.
i found the wiring diagram for the buick/tta. and its all wired fine. There is 0.00 knock retard on my logs. Maybe the engine just isnt knocking at all. The sensor, wiring, and module are good. I guess its just not knocking.
I'll keep a close eye on it.
