Re: Exhaust question
... With code59, you should be able to control your boost with no exhaust.
Maybe it's the elevation, but our experiences have been very different. No boost controller can make the door open more then physically possible. I have no doubt that no cat and a stock turbo would have destroyed my engine on the first wot.
I wanted to know if it would hurt my truck without the cat...
Will it hurt yours? We can't tell you for sure, but it might.
With just a downpipe and the actuator rod disconnected from the lever on the wastegate door, which in theory would result in 0 boost, my truck would have made way too much boost, I wouldn't be surprised if it would make 25+ psi. I could not go more then about 60% throttle before getting kr.
I now have a 10cm exhaust housing on the stock turbo, no cat and a 2.5" see through muffler and it still makes a little too much boost.
http://www.syty.net/forums/showthread.php?t=58329
