leadfoot
I thought I would share my project with anyone interested.
I am putting in the AWD turbo 4.3 into my '02 Xtreme. -But you contest, the AWD/4X4 frame are entirely different form the 2WD frame! This is true -which is why I procured a 4X4 frame. (It has the dual piston front calipers, disc brakes in the rear and a 3:42 posi)
Ever since I bought the clone several years back I have been in love with it. However, the truck was aging and I needed a larger capacity vehicle for work/play. So I bought a used '02 Xtreme. So I though I would merge the best of both together:
Donor truck: AWD 4.3 turbo engine/700R4 (66Kmiles;1992) in a 1987 2 door S10 blazer.
Recipient truck: '02 extended cab Xtreme (4.3 auto)
Common denominator: '99 extended cab 4X4 frame (ZR2 optioned with regular frame)
First I will strip and POR-15 the frame. The frame was in a flood, so it had advanced rust.
Then install the engine/trans/tranfer case ( The front axle is already there, but I am not sure if the 'phoon front shaft will bolt up)
Then remove the cab and bed from the Xtreme and drop them on the restored frame.
The wiring should be the *fun* part
I will be power washing,cleaning and painting as I go along.
It's a good sized project and I hope to get it up and running before swapping out suspension components and upgrading the engine.
