the baPhoon
:rant: So my S10 suspension and steering has been a little fishy. I get a little spare time and get her up on jack stands. Both lower ball joints are shot to hell, inner and outer tirods are TOAST. I had the entire front end rebuilt just under 2 years ago and put less then 20k on the new components. 1200 bucks later i find out they didnt change much but the upper balljoints and throw on a new Idler arm... thats another story. Back to the topic.
I run down to the local auto zone and rent a heavy duty pickle fork and ball joint press. I get home and start the teardown. Everything was going great. Then i hit a snag, the ball joint doesnt wanna press out. Cue the 5 pound hammer :lol: It plops out with a thud and i continue about my buisness. I bust out with the press and get everything lined up. To my supprise the damn press isnt big enough to fit over the ball joint and lower controll arm with the 2 cups and the cup fittings. At this point im a little pissed, but no big deal. Ill get the joint started using a little inginuity (sp?). I get the jack and brace the bottom of the balljoint with the jack and start a`jackin. The balljoint absolutly refuses to go in straight. After 3 retries i decide to take another route. Oh did i mention the press end of the cup was so damn used it would barly cradle the balljoint? Anyway i just put the upper cup on the controll arm and decide to not use the lower cup and just use my Gorilla strength. Every few cranks i get (no air tools at this house YAY) into the joint i smack the LCA with the 5 pounder to help easy the joint into place. Finally i get it far enough into the LCA that i can get the cups on. I torque it into position and low an behold when i get the cups off my hammering has completely and totally annihilated the ball joint. Its so bad i can hold it in the palm of my hand and shake it and the bolt end just flops around loosly. Not only did they give me a broken tool, they gave me a tool that wouldnt even fit my application. Im not worried about the 14 dollar balljoint. Im just rather perturbed at the utter and total lack of any knowlege in the local auto zone. :rant: /off
Needless to say the "zone" is going to have a rather irate customer tomorrow after my job interview :tup:
