F-ing auto zone loner tools.
the baPhoon
:rant: So my S10 suspension and steering has been a little fishy. I get a little spare time and get her up on jack stands. Both lower ball joints are shot to hell, inner and outer tirods are TOAST. I had the entire front end rebuilt just under 2 years ago and put less then 20k on the new components. 1200 bucks later i find out they didnt change much but the upper balljoints and throw on a new Idler arm... thats another story. Back to the topic.
I run down to the local auto zone and rent a heavy duty pickle fork and ball joint press. I get home and start the teardown. Everything was going great. Then i hit a snag, the ball joint doesnt wanna press out. Cue the 5 pound hammer :lol: It plops out with a thud and i continue about my buisness. I bust out with the press and get everything lined up. To my supprise the damn press isnt big enough to fit over the ball joint and lower controll arm with the 2 cups and the cup fittings. At this point im a little pissed, but no big deal. Ill get the joint started using a little inginuity (sp?). I get the jack and brace the bottom of the balljoint with the jack and start a`jackin. The balljoint absolutly refuses to go in straight. After 3 retries i decide to take another route. Oh did i mention the press end of the cup was so damn used it would barly cradle the balljoint? Anyway i just put the upper cup on the controll arm and decide to not use the lower cup and just use my Gorilla strength. Every few cranks i get (no air tools at this house YAY) into the joint i smack the LCA with the 5 pounder to help easy the joint into place. Finally i get it far enough into the LCA that i can get the cups on. I torque it into position and low an behold when i get the cups off my hammering has completely and totally annihilated the ball joint. Its so bad i can hold it in the palm of my hand and shake it and the bolt end just flops around loosly. Not only did they give me a broken tool, they gave me a tool that wouldnt even fit my application. Im not worried about the 14 dollar balljoint. Im just rather perturbed at the utter and total lack of any knowlege in the local auto zone. :rant: /off
Needless to say the "zone" is going to have a rather irate customer tomorrow after my job interview :tup:
jimmyz79
Re-Member
Re: F-ing auto zone loner tools.
I'm a little confused here. The original ball joints are rivited in. You have to drill/chisel out the rivets and after separating the hub, they can be pryed out. The replacements are bolt in. Why do you need a press?
sy2207
The uppers ball joints are riveted on but the lowers are pressed. I think most GM vehicles are like this.
motorhead
slice the tops of the rivots with a cut off tool in an x pattern then hit it with a sharp air chisel. come off like butter. finish driving the rivots thru with a punch adapter on the air chisel. wack the side of the knuckle with a hammer where the tapered stud of the joint goes thru and it will pop free.
sy2207
I can bitch about autozone for hours but unfortunately they are the closest store to me. I think every press, puller, or specialty tool has not fit or has broken. I think if you bought that 5lb hammer at AZ then it too would have broken. My experience with their ball joint press was no better. It had to use some cheap ass Lithuanian metal since the threads stripped. I was wrenching hard on it but I couldn't believe that a bolt at least a half inch would strip out in this damn thing. It was stuck around the A arm and I had to cut it off. And of course they didn't want to take it back and blamed me for stripping it.
motorhead
I thought all lower bjs were rivoted on sy/ty Ive done lots of 4wd t-trucks and they were all rivoted.my sy is rivoted as well. ??? do you have aftermarket ctrl arms?
jjorgensen52
NHSTE - I'm the only one!
Only 2wd's have press fit ball joints to my knowledge, I just did these in the GT... and what a bear it was
GT
Ty
motorhead
I assummed he was doing his typhoon,thats where I got confused.
My advise is get oem bjs and a good ball joint press. if there is any rust,nicks,or burrs in the bore of the ctrl arm clean it up first.should press in easy,never had a problem.
GarnetTy1473
I broke an autozone damper pulley puller on Sunday pulling the one of the dragster. Never seen one on so tight before. What do you expect from a $15 tool.
the baPhoon
Ill post up some pics of the aftermath heh. I blew that balljoint to hell. On an up side i got me a J O B!
Overnight order selector at B.A.P Import auto parts. 10 bucks an hour 48 hours a week. Medical dental and PET insurance (yeah you heard right, if my mongoose gets a tumor its covered).
I think i may have to just buy a damn press. Itll be handy to have around anyhoo.
The damn press was 99.99 and the biggest turd of a tool ive ever used. Who the hell sells a tool, that requires another tool to use?! We went so far as to just set the bottom cup holder plate from the press on the jack and tried to use the truck weight to get it started but that wouldnt work. With the joint freshly placed in the hole the press was about half an inch too damn small, 1/4 inch on either side of the top and bottom cups. We did grease the slot, and even got it started then maced it with PB juice to no avail. Any help would be lovely as the dime sits in the garage like a neglected lover :(
