im using the caspers electronics adapter system for a typhoon and i see where it has a connector labeled "esc module"
http://www.casperselectronics.com/store2/product_info.php?cPath=19&products_id=1378
and i see where the FAST system lists in its instructions that if you want to use the knock retard feature that you need an add on module and they recommend a buick module.
is this module the DRAC unit? and can i just plug the syty one in? or do i have to go get a builck module? if i use the buick module isnt the filter going to be set up all wrong for a 4.3?
thanks
e
thanks
e
