no offence taken. ill try to explain better. even though a 2 bar sensor similar to the gn is in the truck, like the gn when you add fuel by a high perf fuel pump ,and hot wiring it to the alt by the way of a bigger dedicated wire ,as much as 20% more or 2+ volts is added to the fueling system. now the hard part. gauging from exhaust temp and 02 volts and fuel pressure you can surpass 15 psi easly . my gn can do 25+ psi even though the factory maf can only calibrate 255ml per min.stay with me, the factory wastegate solenoid is not hooked up to the hoses ok. its manual, so as long as i got fuel, and im rich and exhuast temp is resonable and kr is very very low ,im safe. but no one yet has answered my origanal question.
