Feedback on stock GM 2 bar map sensor
Syclone22
O.K guys our SYTY trucks came stock with a
GM 2 bar map sensor that should be good
to 15 psi of boost pressure !!
When raising the boost pressure past 15 psi on this
map sensor what will happen ??? :roll:
Quickstop [UK]
Combating adversyty.
Re: Feedback on stock GM 2 bar map sensor
I was wondering how to embed that! Strange it doesn't work or me though.. hmm...
IpHoOnDyou
Sytyarchives.net or com? Forget which, it will explaine what a 2 bar an a 3bar do.
MRKING
New Parts for Old Trucks
Google what 1 bar of manifold air pressure is , then times it by 2 or 3 .
Bonus round : what would 4 bar equal ?
It's just a six
Super Member
How bout I'll trade you my ATR Pittbull street chip,, good for proven 12.29 ET for your ATR intercooler?
I ran 18-19 PSI w/the Pittbull chip & factory 2 bar map sensor.
Think about it.:tup:
Syclone22
Thanks for the offer but i may need more than
the ATR chip to do a trade !!! ;)
With a 2 bar the sensor stops reading anything past 15psi, so the ecm fuels the motor for 15psi. If your running 16-17psi probably not a huge change in fuel requirements. 20psi, could very well require a lot different fuel and timing which the sensor didn't see, so the ecm can't properly fuel it.
If it goes lean far enough, then you won't be worried about map sensors but have moved your area of interest to pistons, rods, bearings, etc.
Syclone22
Great feedback what will happen by cheating the fuel system
after 15 psi by installing a nitrous fuel solenoid with boost trigger and tune
with the jets to get the right A/F ratio for 20 psi the timing will remain the
same so the retard will also be activated if detonation is present !! :D
