Free mods?
R
rugby4u
Guest
What kind of Free mods can you do to a sy/ty? My friend has a 93 TSI Eagle Talon and he did some free mods to give him a little bit more boost. I guess what i am wondering is what can you do to "get-more-boost" free mod wise?
InvisiBill
That doesn't mention hotwiring the IC pump. The ECM doesn't turn on the IC pump until it's way too hot to do any good. If you T in a ground wire to the yellow wire on the passenger-side relay on the firewall, the pump will run whenever the truck is on. That keeps the coolant flowing through the heat exchanger, and thus keeping the incoming air cooler and denser.
For pretty cheap, you can also replace the metal IC lines. Insulated rubber hoses keep the coolant from soaking up extra heat, unlike the stock metal lines that are bolted to the engine.
A lot of trucks aren't as fast as they could be simply because they haven't been kept up properly. Check out the FAQ and Readme to the left...
Tooky
Serious about performance
My truck ran 14.2 on 12# boost when I got it from previous owner, it was messed up with a boost control problem preventing full boost, and some other issues. I fixed those and did the free/cheap mods like 160* thermostat and hotwiring the factory IC pump and using rubber heater hoses and changing the ignition and I went to a 13.3 with a few tenths left in her still using the stock chip. So the ignition and tuneup maintenance is critical to performance.
