Front end rebuild
ircwet
What are peeps doing on front ends? Rubber or Poly? Yes I did try the search feature but it keeps comming up with this >>>
Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 262144 bytes) in /home/sytynet/public_html/forums/search.php on line 1151
Chest Rockwell
Re: Front end rebuild
For what it's worth, I went with parts from PST. Poly bushings, along w/ a rebuilt steering box and solid shaft really improved the handling. I ordered mine online, but got a call since they apparently don't know what size front sway bar a Typhoon has. Otherwise, very happy with the parts and improvement.
asmo
Sy #2918
Also the search on this site kinda sucks hard to work with.
on google type site:syty.net then what u need like front end etc. it will pull up all the threads its alot easier imo. this works better than the forum search.
Blazerspeed
It depends on what you're looking to do. Full rebuild, just the steering shaft and a ZQ8 steering box, rip out the front axle and rebuild it.
Personally I'm rebuilding everything. I picked up a poly bushing kit from a member here, along with a steering box, and a front axle. Eventually while I have everything apart I'm doing the suspension along with some electrical work. Take a look through out the suspension and drive train sub-forums; you'll have to do some digging, but there is plenty to keep you occupied.
Chest Rockwell
What he said, x2. While I had the dif out, I replaced the busted driver's-side motor mount, and the leaking turbo oil drain. So much easier with all the suspension/steering/dif out of the way.
ircwet
I am doing ball joint, tie rod ends, yadda yadda yadda....not worried about steering shaft or box
Treymen
Do it anyway while you have all the other stuff out. This is probably the most noticable improvement on our trucks is the ZQ8 and Jeep shaft. You have no idea how bad your steering is until you do it.
SY2455
70's Veteran
X2 what he said. I went with PST as well. For the front Diff I used Energy Suspension because PST said they didn't have those bushings.
I had my whole front end done last Sunday (Thanks again Darriel) and I used the PST Poly Graphite. Everything was changed: pitman arm, idle arm, inner and outer tie rods, all bushings, upper and lower ball joints, Jeep shaft and a AGR steering box. I also have Bilstein Sport shocks installed. The only thing left is a rear sway bar. I have decided to go with an ATR. I love it. My suspension is so stiff I can drive over a quarter and tell if its heads or tails. LOL
It all depends on what kind of ride you want. If you want smooth ride don't get poly.
If you are going to go with the poly, spend the extra few $ and get the graphite impregnated parts. The regular poly parts squeak real bad.
SY-1193
I also went with PST . The ride is a bit stiffer and it is squeek free. Best advice they gave me was to use the lube they provide with the kit on the parts and it will break in properly and be squeek free. I used Moog for all the ball joints, tie rods.
Suny
I have to do front end work to my truck too, looks like besides tires, im also gonna need a ZQ8 box Jeep shaft and everything else here. Thanks for the info guys.
