Aeroking
e.i.
I plan on taking my truck apart again this winter to paint and coat a few things. Before I do, I wanted to throw it up to see if anyone wants to grab it.
1991 Syclone, 56,000mi on truck, 12,000 on motor, 1,000 on trans
Condition:
Paint 9 of 10
Body 9 of 10
Interior 8.5 of 10
Chassis 8 of 10
Bought the truck in 2006. Built the engine and trans. in winter of 2008. Block machining & trans. was done locally, everything else was done by me.
The actual list is longer, but these are the highlights.
Chassis:
KYB shocks all around
Belltech rear leafs
Belltech rear swaybar
Caltracs bars
RPM solid motor mounts
LS1 Camaro disc brakes all around
ABS delete, full system and harness removed
Hydroboost
Adjustable proportion valve
Rear shaft safety loop
Front limiters
ZQ8 box, Solid Jeep shaft, Rancho stabilizer
Drivetrain:
HD front propshaft
700R4, Rossler Terminator 2
TCS 9/11 converter 2800 stall
B&M cooler behind grille
Rear diff alum girdle cover
Engine:
Syty block, .030 overbore, 4-bolt splayed mains (center 2)
Melling HV pump
Eagle H-beam
SpeedPro pistons & rings
Comp hyd. roller cam, custom grind by E-Rue @ Turbotime
Comp 875 lifters, Comp hard pushrods, Comp 1.52 rockers, ARP rocker studs
Comp double roller timing set
L35 heads from John Waller, Comp beehive springs, ARP head bolts, Edelbrock covers
Stock intake, stock plenum, stock exhaust manifolds, stock fuel rail
RPM 58mm throttle body
Homemade air-air intercooler, all 3” stainless powdercoated black, ebay 3” core, HKS SSQV
Remote oil filter and cooler removed, complete air conditioning system removed
Fuel:
Twin Walbro 255lph in-tank
Racetronix harness
billet adjustable regulator
Alky Control, custom 4gal tank in bed
PTE 60/65# injectors, pen style
Ignition:
ProComp billet distributor
MSD blaster coil, MSD cap & rotor, Taylor wires, NGK plugs
MSD 6AL ignition box, MSD signal filter, jumper harness
MSD 2-step module
Optima redtop, mounted in bed
Electronics:
Stock S10 tapedeck head unit with input jack added for MP3 player
Autometer boost gauge, Autometer fuel press gauge, Caspers knock gauge
FAST Classic (SpeedPro) ECU, FAST L98 harness
Exhaust:
Stock manifolds
PTE 6265 turbo, CEA billet wheel, journal bearing, 4” inlet/2.5” outlet, SyTy .85 housing
Homemade 3” downpipe, stainless, JetHot 2000 coated black
Tial F38 ext wastegate
Homemade 3” stainless exhaust, SLP resonator, Magnaflow muffler, side exit with square tip
Exterior:
2” cowl hood, steel
Clear marker and turn signal lenses
Camaro Anniversary wheels, 17x9, Yokohama tires 275s
It’s been to the track a couple times without a clean pass. Mostly use it for exhibition races, and street competitions. Tough to beat.
When the rebuild was fresh it made 350hp/460trq to the wheels, on a 72 turbo, low timing, stock IC, and straight pump gas. Last month it did 460hp/560trq to the wheels on the current mods with a safe tune. I’m sure 500/600 is possible with some race gas.
I don’t need to sell it. I just bought a new house and this is a good stopping point to let it loose and bring in a new SyTy project. $25k would take it today title in hand. I’ll throw in the set of corvette sawblades that no one wants.
Please don’t post “where were you 2 months ago”, and “wish I had the money”. Thank you.
Condition:
Paint 9 of 10
Body 9 of 10
Interior 8.5 of 10
Chassis 8 of 10
Chassis:
Belltech rear leafs
Caltracs bars
Hydroboost
Front limiters
Drivetrain:
HD front propshaft
Engine:
Melling HV pump
Eagle H-beam
Fuel:
Racetronix harness
Ignition:
MSD 2-step module
Electronics:
Exhaust:
Stock manifolds
Exterior:
2” cowl hood, steel
