fuel lines
cloneman315
has anyone ever bought the needed parts(braided an) to go from the sender unit to the fittings by the transfer case,
blackty
Re: fuel lines
Brian, I was looking at some stuff from Summit. Let me know what you think...NEX14036 is an example of one of the lines. The Saginaw fittings were listed on here. I think the # was SUM-220009. I'll double check my notes. Had it all written down. This is off memory...Jim
Ok, these #s checked out. My plan was to go to filter with flex line and then use a -6an to -6an fitting by tc for return.
Keep in mind that this would be -6an supply and return. You *may* need more volume for your build.
cloneman315
Re: fuel lines
thats what im thinking,since we have all these parts stores around here(nascar country) I might just bring the new sender there and get a list.
blackty
Re: fuel lines
According to their description, race teams are changing to the new kind as opposed to the stainless braided. Nascar country should know...Jim
blackty
Re: fuel lines
Change from the Summit # to - 9894dbherl & 9894dbjerl. These are female fittings that should go right on the sending unit. Too many notes...Jim
