Re: fuel lines
Brian, I was looking at some stuff from Summit. Let me know what you think...NEX14036 is an example of one of the lines. The Saginaw fittings were listed on here. I think the # was SUM-220009. I'll double check my notes. Had it all written down. This is off memory...Jim
Ok, these #s checked out. My plan was to go to filter with flex line and then use a -6an to -6an fitting by tc for return.
Keep in mind that this would be -6an supply and return. You *may* need more volume for your build.
