Re: Fuel Pressure Gauge Mounting
I have been running a Goodrich remote fuel pressure line that I bought from
RPM over seven years ago with no problems. You can see the fuel rail end here:
And here's the other end connected to the fuel pressure sender on my SPA dual gauge:
The remote fuel pressure line allows you to mount the sender somewhere other than on the fuel rail to prevent fatigue issues. You will have to remove the core out of the fuel rail to use this remote fuel pressure line. The core remover that is used on tires is all that you need to remove it.
