Fuel Pressure?
SY756
I have my FP set at 40. When it's running, the gauge "flutters" from 43 to 35. It seems like every time the injectors fire, that's when it goes off and the needle stays pretty much at the right pressure, just it bounces around, really fast. I mean the needle pretty much stays in the same place but you can see it bouncing up and down...Is that normal....I must admit it is a AZ FPG but its been good in the past...and I just put in a 255 pump.....just curious...I should know this but I am just getting back into the game..Don't use it, you lose it.
turbodig
Re: Fuel Pressure?
Air in the line, most likely.
NecroWolf
lost marbles member
Re: Fuel Pressure?
dirty/sticky injector? do you have a plug or two that looks richer than the rest?
