Fuel pump wiring??
SBNova
I had a problem a few months ago. I let my Ty idle for about 1/2 hour, and when I drove off, I got about a mile and it ran like it was out of gas. It would idle roughly, but the slightest load would make it want to stall. I tried to keep it running for about two miles hoping it would "cool off" but it kept running bad. I pulled over, let it sit for an hour while I went into WalMart and when I cam out I started it up and rove away as if it never had a problem.
Two months ago I was driving down a rather hilly road- for Florida- gas gauge reading empty. I was trying to make it to the next station where gas was cheaper. On this day it made the same symptoms until I pulled over for a few minutes. I turned around, got gas and all was well.
Since then Ive been carrying my fuel pressure gauge with me should it happen again.
Yesterday, it happened again. I completed a 60 mile hwy commute, and parked the Ty for about 15 minutes. I got in, tried to drive off and only made it two blocks before the symptoms began. Rough idle, inability to accpet any load or accelerate, and stalling. I checked the fuel pressure and it was nill, 0. I cycled the key, and the pump sounded funny, although its hard to hear while I turn the key and try to hear it over my louder than stock IC pump. It sounded bogged down. Ive had a new relay in the glove box from the previous owner, so I tried it- no differance. Then I jumped the relay socket with a paper clip, and the pump still sounded slow, and only made about 10-15 psi at the rail- the same as with either relay at this point.
My Ty has a Walbro pump, that I bought new about two years and not that many miles ago. I got the truck home and dropped the tank. I cycled the key a few times with the pump wired but out of the tank and I dont think it sounded right. I think it sounded slow. As soon as I got out the volt meter, it sounded better, and voltage with the pump unplugged was 12.43, and at the battery was 12.44. The *new* sock I installed with the pump was nice and clean, and still snug on the pump. The screen on the pump inlet looked new- no debris.
Has anyone ever had a voltage supply problem to the pump like this? Is my pump going out? I let it run in my hand for a solid minute or two, and it ran fine and didnt get warm at all. I checked the rsistance of thepump, and athough I dont remember what it was- it was almost the same as my old stock pump. So now I have a short length of wire in the Ty to jump the fuel pump from the hot + "posts" on the firewall to the relay socket. It ran today all the way to work with no problems at all.
One more thing, with they Ty running, I noticed that my fuel pressure gauge jumps around. I cant remember if it did this before or not. At idle, it jumps from 35-45 psi, and you can feel the gauge "pulse" in your hand. It does vary the pressure with rpm/load. The reading still jumps with the vacuum off the FPR the same amount.
Does anyone have any ideas or similar stories????
skwayb
NWSTP
Re: Fuel pump wiring??
X3
I had the same problem with only 1000 miles on my Fuel Filter. It ended up being the filter decided to implode. Same symptons you are describing exactly.
SBNova
I put in a new one less than 5k miles ago, right before I cahnged the pump. I guess it wouldnt hurt to change it out again. I just dont want to be stranded on the side of the road.
Oh, and is there an easier way to drop the tank on a Ty? Those outlet and return hoses are HELL to get to on top of the tank.
TYPHOOL7
Post Hawk
couldnt hurt to try, yep, and, lol i wish and i know, such a bastard job.
SBNova
Last night I changed out the fuel filter. When I took out the old one, it dribbled out some dirt so I guess its possible that the problem is the filter. I havent driven it yet to know if its fixed though. I'll definately post back in a few weeks if it doesnt happen again.
graham1524
Well-known member
im having problems with my sy but it idled for a little bit then it sputtered and now won't start i fiugre the fuel pump is dead but how do i make sure i need a new one
Flyin Ryan
hated cuz he drives fords
apply 12 volts to the test port, see if the pump turns on and how much pressure you get... if not try swapping the relay. There are two relays above the brake booster.. swap them and see
sly dvl
Ya, it's got a Turbo
Hate to rain on your parade but the filter won't be your problem. If a filter becomes plugged it stays plugged so you'll likely never get it started again. Since it started after sitting it's not a plugged filter.
Also, a plugged filter will still give you pressure readings close to normal KOEO but will of course have insufficient flow for the demand.
If you've run the pump dry (empty tank, on the bench for testing, etc...) then it's junk. You can't run a pump dry since they rely on the fluid for cooling.
supersports10
graham1524 said:
is the walbro pump to much to run on a stock engine or will it work fine?
i will work perfect!!
in fact it is one of the first upgrades everyone should do. :D
sly dvl
If you're upgrading to a Walbro pump you should consider upgrading your fuel pump wiring harness as well.
SBNova
Well, my problem is not fixed. The fuel filter didnt do the trick because it happened again. Its been a while since the last episode, but its exactly the same symptoms;
Drive for ~30-45 minutes, hot outside, and it will either sputter while cruising or stall when you coast to slow down. Either way it wont stay running. I can sometimes feather the gas peddle and limp it along- maybe triggering PE/AE to crutch the lack of fuel supply? When it dies, I can press the needle valve on the fuel rail and get a "pssst" of air. The pump usually sounds like its struggling when this happens, but its hard to tell for sure since im usually on the shoulder of a busy road.
Im guessing the pump is going out, or the voltage isnt getting to the pump. When its doing it, Ive jumped the fuel pump relay from the "hot" on the firewall with no change.
Damn I hate taking that tank down!!!!
SBNova
I noticed that my problem was becoming more frequent. If I had less than half a tank of gas, it would surely happen in abouyt 30 minutes of driving time. One of the last times I had a problem, it was sputtering bad. I had between a quarter and half tank. I stopped for gas just to see if it would make a difference, and it did. My truck went right back to normal, instantly. Ususally I would have to wait up to an hour for normal operation to resume. I think the pump overheats whenever it isnt submerged in fuel.
I changed the pump yesterday. We'll see if it happens again. Ive got my fingers crossed.
