SBNova
I had a problem a few months ago. I let my Ty idle for about 1/2 hour, and when I drove off, I got about a mile and it ran like it was out of gas. It would idle roughly, but the slightest load would make it want to stall. I tried to keep it running for about two miles hoping it would "cool off" but it kept running bad. I pulled over, let it sit for an hour while I went into WalMart and when I cam out I started it up and rove away as if it never had a problem.
Two months ago I was driving down a rather hilly road- for Florida- gas gauge reading empty. I was trying to make it to the next station where gas was cheaper. On this day it made the same symptoms until I pulled over for a few minutes. I turned around, got gas and all was well.
Since then Ive been carrying my fuel pressure gauge with me should it happen again.
Yesterday, it happened again. I completed a 60 mile hwy commute, and parked the Ty for about 15 minutes. I got in, tried to drive off and only made it two blocks before the symptoms began. Rough idle, inability to accpet any load or accelerate, and stalling. I checked the fuel pressure and it was nill, 0. I cycled the key, and the pump sounded funny, although its hard to hear while I turn the key and try to hear it over my louder than stock IC pump. It sounded bogged down. Ive had a new relay in the glove box from the previous owner, so I tried it- no differance. Then I jumped the relay socket with a paper clip, and the pump still sounded slow, and only made about 10-15 psi at the rail- the same as with either relay at this point.
My Ty has a Walbro pump, that I bought new about two years and not that many miles ago. I got the truck home and dropped the tank. I cycled the key a few times with the pump wired but out of the tank and I dont think it sounded right. I think it sounded slow. As soon as I got out the volt meter, it sounded better, and voltage with the pump unplugged was 12.43, and at the battery was 12.44. The *new* sock I installed with the pump was nice and clean, and still snug on the pump. The screen on the pump inlet looked new- no debris.
Has anyone ever had a voltage supply problem to the pump like this? Is my pump going out? I let it run in my hand for a solid minute or two, and it ran fine and didnt get warm at all. I checked the rsistance of thepump, and athough I dont remember what it was- it was almost the same as my old stock pump. So now I have a short length of wire in the Ty to jump the fuel pump from the hot + "posts" on the firewall to the relay socket. It ran today all the way to work with no problems at all.
One more thing, with they Ty running, I noticed that my fuel pressure gauge jumps around. I cant remember if it did this before or not. At idle, it jumps from 35-45 psi, and you can feel the gauge "pulse" in your hand. It does vary the pressure with rpm/load. The reading still jumps with the vacuum off the FPR the same amount.
Does anyone have any ideas or similar stories????
