General Questions about Ultimate Chips.
SY2455
70's Veteran
After reading all the links that I have and doing a search, If anyone can answer these it would be awsome. My Ultimate chip is a STG Ultimate Chip Version 6 so that is the reference point that the questions come from.
1. What are the changes that take place as you move to the later verisons?
2. Are the changes better, More beneficial ?
3. In the later verisons, Is there a trade off if I up grade?
4. If I have a problem can I still get it looked at?
5. If I go the upgrade route to vortec heads, Can I get the Ultimate Chip redone to work with these heads?
6. What is the cost to upgrade to a later version?
I won't be able to check this posting until Thrusday so knowing that I want to say TIA for the answers to these Questions.:tup:
TYTILIDIE
METH HEAD
Re: General Questions about Ultimate Chips.
Ild say have a custom chip made. Its the only way to go these days. I had the Ultimate and cant say I was incredibly impressed with it. I was at first only because I could run more boost but it was very rough trying to get everything dialed in properly which never happend. Ive been doing my own tuning along with many others here and if you ask anyone who is doing this its the only way to go.
Tooky
Serious about performance
Others can probably give more information, but here's what I think:
It seems like the ultimate chips are being phased out, or at least the support has been cut way back. My understanding is this was not a professional company product, but rather the product of a handful (2?) of knowledgeable Syclone/Typhoon owners offering a product to the community. One has moved on from SyTy and the other could have as well (not sure).
The Ultimate's place in SyTy has been that of the original source for 3 bar code, as well as the only "off the shelf" one-size-fits-all multi-chip for modified trucks. As such it has the limitations of any universal chip. Now that the tuning tools have become more advanced (i.e. the real time tuning on a stock ECM with a Moates.net Ostrich and TunerPro make the stock ECM work just like a standalone F.A.S.T. unit, and real time WBO2 ECM datalogging), more people are doing their own custom tuning and achieving better results than the Ultimate. Although most people's chips are still based off the original Ultimate BINs (particularly because of the 3 bar code).
To answer your other questions, V7 was leaner than V6. They did a new release of V10 and V11 with are similar to V6/V7 but my understanding is they have some tweaks and generally less timing advance to result in a safer, slightly weaker performing tune. This applies to the stock injector Ultimates.
There are 3 more Ultimates. The "50# Stock Motor Ultimate", the uncommon "50# L35 Heads/Cam Ultimate" and the more common "50# Vortec Head/412 Cam Ultimate". None of these has the pushbutton boost control like the original stock injector one. Instead they offer 2 sets of 7 programs (street and race) which have varying WOT fuel (rich or lean). BG said the various turbos and different actuators made it almost impossible to offer boost control for modified motors.
Some of the later models offered a knock sensor LED.
Any of them can be changed to a different set of programs by replacing the EPROM with a different one, and anyone could burn you one. However they do not accept the Flash chips most people use, it seems they only work with UV-erasable EPROMs and not many people work with those anymore.
turbodig
That's generally a good overview. The versions were mostly fueling, and there were differences in the display box (Big black box, radar-style, gauge-style). The boards that the MEMCALs mounted to went through a revision or two.
I've done a couple of re-programs now, using the 29F040 and a re-wire of the cable/connector. This allows it to plug into a Moates board, and run larger code segments.
(ie, code $59)
Full custom ultimates can be done, but they get to be an expensive proposition, due to all the time involved. If you're doing it any justice, it should take a good day or two on the initial driveability, and 3-4 hours on each individual bin thereafter. (And that's with the truck in your presence). So, you're talking 50-60 hours. Figure normal hourly rates where you are, and that quickly gets into big $$..
Realistically, I'm not sure why you'd need much past a street gas bin, a race gas bin, and maybe a valet/security. If you run alky, it'd be even less than that.
