Hard wire diacom?
SY732
Anyone see a problem with hard wiring a power inverter for diacom?
Is there a good always positive source in the cab?
TIA
Daron
I would get a laptop that runs off of 14v, like most Toshibas do (including my Libretto). If you hardwire the inverter you will find it will drain your battery in short order if you do not switch it off when not in use.
turbodig
Also, Radio Shack makes a DC/DC converter
gadget, adjustable for 9-22v, or similar.
Lotta laptops are 15-18 volts, and this'll
work for it.
I'm trying to wire up a setup to power the
Pocket Programmer, Eprom Eraser, and the
Laptop all off the gadget, without the clum-
sy inverter.
Depends somewhat on your laptop, there's only
so much current the converter can supply.
later,
Dig
