Re: Have a short I think
Man....you really opened up a can of worms with that one. Unfortunately, there are only about 458 wires in there that could be messed up. With the problem being intermittent like it is, you might get after it with a multimeter and find NOTHING wrong, but still have an issue. If I were you, the ones I would check first are all the wires related to the basic operation of the truck; wiring for the ignition module, coil and power / ground to the ECM. The very first thing I would check is the ECM chassis ground. If you grew up in buttcrack USA like I did, and had a straight up antenna for your house TV (no cable, no satelite dish), then you'll recall moving the bunny ears and what not to get a better picture. Remember how it would come in AWESOME as long as you were standing there holding it, but as you let go, the picture would suck again? Kinda seems like you have the same deal with the ECM. There is a hard chassis ground for the ECM, then internally to the ECM, there are a couple other "reference" grounds that all of the sensors use, so they are kind of "calibrated" to each other instead of one sensor referring to a ground that is nice and clean, and another sensor referring to a ground that is sucky. Lemme to a little looking on my end and I'll give you a list of ECM plug pins to verify a good ground to. The ECM chassis ground is the loop of wires on the first intake manifold stud right behind the alternator; might as well make sure that ground connection is good first off.
-adam
