Having Tuner Pro 4 and 5 on the same computer
TYTILIDIE
METH HEAD
I don't know if its just me but I am trying to keep TP4 and 5 on my laptop and it seems like its one or the other. When I installed 4 it erased 5. When I installed 5 it erased 4. Is there something I am failing to do here?
ItsMyTy
Life is beter at 25 PSI
Re: Having Tuner Pro 4 and 5 on the same computer
I have the same need for both..
I installed TP4 normally
Then installed TP5 to a different folder than the default
The start menu icons may still overwrite each other. You can easily make new shortcuts from the install folders.
Big Mike
I have Tp4 and Tp5 on the same computer working but you may not want to mix bins between the two.
skwayb
NWSTP
Editng the same bin with both programs is fine. The bin is the same format regardless of which program you use to edit it.
Only the file labled XDF -TP5 ONLY and ADX files are specific to TP5.
nallj92
i have both 4 and 5 working on the same computer, just when installing, install to a different folder. I just had to have two different labeled icons on the desktop to make sure i knew what was what before opening.
TYTILIDIE
METH HEAD
Im just trying to tune the trans bin with TP4. No matter which version I try to use it will not save changes on this bin. I am currently running the bin on a burned chip but I need to make changes and like I said, it isn't letting me. I am thinking I am going to be needing to go back and fourth, I have two Ostriches I want to use but if I cant make any darn changes on the Trans bin I dont know what I am going to do here.
TYTILIDIE
METH HEAD
Tried that, it still doesn't work. What sucks is that I had both of these registered. I guess I'll have to delete all of it and re install.
nallj92
so when you install the 5 it ovewrites 4?
not sure about the trans bins at all though.
SY-1193
When you re-install: search for " *.tpk " it will pull up your registry files -files sent to you by Mark Mansur to register.
Note:
TP5 supports two instances running at once for those also controlling a separate ECM for a transmission. Found in: TOOLS -> CUSTOM TOOLS -> NEW TUNERPRO INSTANCE.
HTH:tup:
