help finding cause of knock
ppress79
I need suggestions on finding false knock. I hacve an '01 stock vortec motor, RPM stage 3 turbo and solid motor mounts and a poly trans mount. At high vacuum (10-20") as I lightly apply throttle I get a rattle that sounds a bit like a liscense plate rattling. I can hear it as I accelerate from a stop but I cannot get it to do it if I rev the engine in neutral or if I apply the throttle while holding the brakes even up to 2-3 psi and tire spin. It doesn't do it every time and when it happens I can apply heavy throttle and it goes away. Most often in the 1800-2200 range while cruising as I apply and let off the throttle to maintain a steady speed it happens.
I checked down pipe cat and cat heat shield. Torque converter bolts, flex plate bolts, fuel lines and motor mount bolts. I don't know where else to look and could use some suggestions.
Phil
typhoon x
Re: help finding cause of knock
if u have electic fan make sure it has not broke loose my fan broke top two straps was falling in water pump knocking sound when i gave it gas it would pull fan back to rad. and knock would go away good luck
Beavis
Still plays with trucks
fuel line rattle, heat shield rattle those were my problem.
cloneman315
Simple fix,put a wbo2 on it,datalog it and get the tune dead on,and throw that worthless knock sensor in the garbage.
turbodig
My stock brake lines (off the master cyl) made a buzzy license plate rattle. Would also only do it when moving/load on engine.
ppress79
I'll check the brake lines. My fuel lines are isolated so they can't rattle.
Phil
ppress79
I have an RPM Stage 3 dual bb turbo. Could the bearings in the turbo cause a buzzing type rattle and would the knock sensor pick that noise up? It sounds like the noise is coming from the turbo but I cannot really test it by revving the engine and not putting a load on it and the turbo spooling up is about the time I see knock.
Any thoughts on this theory?
Phil
Osmosis
exhaust leak?
Wastegate?
Def sounds like false KR becuase when it's in gear, you can hear it. I would look @ tranny and fuel lines. Anything that can cause false KR. I thought I was having false KR, but I can hear mine. I've got a fuel problem:(
False KR, jack it up on all 4's. Have someone put it in gear and look for any shift...but be careful. Or take it to a dyno:(
