Help Picking Out a Camshaft
tbauer03
TRBOBOX
I was considering doing a motor build one of these days and i am just doing research but when i was looking for camshafts most the cams i saw advertised were for V8's and only a couple v6's Could someone help me out with part #'s, information, pictures, where to get them, what would be a wise desicion for my application etc etc.
jwaller
Evil Genius/SyTy Guru
depends on your application and how fast you want to go and what ability you have to tune it.
the 412 from comp has been tried and true to be a good choice but their and others out there if you want to run faster. but they are less devloped with chips and such.
jwaller
Kramer said:
Why not call Comp's help line? 1-800-999-0853
when it comes to turbos V6's and 4.3L syty trucks they are about as useful as a really sharp stick in the eye.
Captain Morgan
Moderated User
HAHAHAHAHAHAHA......
Ted, how fast you looking to go??? I plan on going with the 412 myself. Ive had a few guys tell me the 422 is too wild for as much driving as I do, ive had some tell me thats silly, I really cant formulate an opinion from this, but its just what ive been told
Either way I figure the stock motor can get me to mid-12's, the 412 will allow me to hit 11.9X's and not have any drivability problems, so thats what Ill be using unless someone convinces me otherwise :D
The 415 from CompCams with the Vortecs drives very nice. Idles very smooth, can't really tell it has a cam at all. Has a little more top end pull then the 412. This is on a truck with a 3k 9/11, ATR headers, PTE63E.
The 415 just has a little more duration on both lobes with the same half inch lift as the 412.
Your results may vary.
Sy769
I have called Comp twice now and both guys said that for turbo applications the 412 grind leaves some power on the table.
Here is one email from them.
Patrick,
I would recommend that you go with a custom grind cam. I have listed
the specs on the spec card below. This cam is going to have negative
overlap and will maintain the boost that is applied into the engine.
PART NUMBER 09-000-8
ENGINE 4.3 V6 ENGINE
GRIND # CV6 3313S / 3312S HR 114+4
DESCRIPTION HYD ROLLER
SERIAL # N/A
INT EXH
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .528 .520
WITH 1.6 ROCKER RATIO
DURATION AT
.006 TAPPET LIFT 269 264
VALVE TIMING OPEN CLOSE
AT .050 INT 1- 39
EXH 44 12-
THESE SPECS ARE FOR CAM INSTALLED
AT 110 INT C/L
INT
EXH
DUR AT .050 218 212
LOBE LIFT .330 .325
LOBE SEPARATION 114
ADVANCE 4
RECOMMENDED CC VALVE SPRINGS 941-16
Thanks,
John
sytyguy
Moderated User
Basically, here are your "shelf grinds" from Comp:
Non Balance Shaft
*09-410-8
- Lift (I/E) = .500/.500
- Duration @ .050 (I/E) = 206/206
- Lobe Separation = 110 deg
*09-420-8
- Duration @ .050 (I/E) = 215/215
*09-430-8
- Lift (I/E) = .525/.525
- Duration @ .050 (I/E) = 224/224
*09-412-8
- Duration @ .050 (I/E) = 206/210
- Lobe Separation = 112 deg
*09-415-8
- Duration @ .050 (I/E) = 210/215
*09-422-8
- Lift (I/E) = .500/.510
- Duration @ .050 (I/E) = 215/220
- Lobe Separation = 114 deg
Balance Shaft
*56-410-8
*56-420-8
*56-430-8
*56-440-8
*56-450-8
*56-460-8
I carry all these camshafts (and any custom grind) for $239.99.
HTHs
Hood
BigAl...
If anyone is interested I have a custom grind cam for sale! I just took it out of my truck it has 3437 miles on it needless to say it looks and measures up like new. I paid almost $300 for it will sell for $200 plus shipping. this cam made 504tq at 15lbs of boost and 93Amoco gas and mild timing(yes I have the dyno sheets). it is a very strong cam and is a proven upgrade to the 412.
BigAl...
Sorry for hijacking tbauer03's thread.
tbauer03
TRBOBOX
I hate the question how fast do you want to go. But after i get my tranny squared away i am hoping for sub 13's after that I want to upgrade the turbo to a pte 61 (not sure on the turbo) Then i want to start my engine build I was thinking Forged Rods and Pistons, l35 heads, new valves rockers etc etc. Then i was thinking cam shaft and i hit a brick wall. I have heard the 412 to be a good upgrade and the 422 to be a pretty wild upgrade and now i am hearing about the 415 and it sounds like the golden middle what do you guys think about that cam. I have heard a lot of guys running the 412 and a few guys with the 422 but never the 415 what is your story on choosing the cams that you guys choose?
rarebit
any of the 3 cams would work well. i wouldnt expect more then 10-15hp difference between any of them (with all other engine parameters the same.)
the bigger the cam, the more tuning you'll need. the rpm band will raise up higher. the 422 would require the shift point to be raised (~5200rpm) where as the 412 and maybe the 415 would not (~4800).
myclone
Not to hijack the thread but Id like to see more input/thoughts on custom grind cams as I plan on using one. Id also like to see some ppls input/discussion on what issues would be worth considering.
What if lift wasnt really an issue as I can go to ~.650 lift before valve spring changes become a pain.
Duration... Im thinking you really dont want a lot of duration to keep the cyl pressure high even at low boost.
Overlap.... Im thinking you will want to keep this to somewhat of a minimum also for good cylinder pressure and since the restriction of the turbo cancels any real scavenging benefits along with the compressor forcing the intake charge in.
Any thoughts or anything I missed? I have looked over the comp catalog offerings (as well as other cam companies) and nothing they offer off the shelf really makes me happy. On the other hand Id like to have some numbers in hand before I call them for the reasons waller pointed out about the tech line. Im sure they could recommend a cam for a N/A SBC or SBF but that is comparing apples and oranges IMO for our applications.
ed hess
race or get outta the way
fwiw
i cant make a recommendation, but the 412 will create a torq monster at lower rpms. There are other cams out there that can give you a more linear power curve and or more power at top end.
i.e. keep you getting good 60ft times without blowing your tires off.
if i had to do it again i wouldve used something other than the 412.
ed
Sy769
both cams they have recommended for me have negative overlap and relatively short duration.
I looked through their catalog and had a few lobe profiles in mind. They can grind any custom grind using the profiles out of the catalog for the same price as a off the shelf one.
I think I'll use something similiar to one I posted above.
~.520-.540 lift
~210-220 duration
~114 lobe separation
0 to negative overlap
From what little I have found to read on the subject this seems like it might be in the ballpark.
Exhaust housing selection can also change cam selection. With a high pressure housing like the stocker reversion is a problem. I am using the Std. housing that comes with the PTE 60. Not nearly as restrictive but I can still see no benefit to a overlap in a turbo engine.
I'd like to have the cam timing info from some factory cars like Subaru,Porsche, etc,
Anyone have any cam timing info from a GN that made good power?
Be interesting to look for trends in similiar engine types and displacements.
tbauer03
TRBOBOX
So will the 412 create more low end torque than the 422 and 415? Does anyway have horsepower and torque vs rpm's graph that shows the curves of the 412 415 and 422 so i can get clear represention of these cams.
leroy
An old hotrodder's advice was "Select the cam you want or think you need, and then go a step milder."
Jim
myclone
Jim
Hmmm.. I kinda always liked my philosophy of "the cams too big when it wont fit in the block" :wink: .
rarebit
the 412 would make the most low end torque out of all three. the graphs for all three wouldnt really differ that much from each other. the torque curves would all basically look the same with the 412 making torque lower and the 422 making torque higher. probably not much more then 10ft lbs more torque for the 412 over the 422. the hp curves would show the 422 making the most over the 415 and 412. not very much more though. maybe 10hp tops. it's not really that big of a deal. any one of these cams would work fine.
from my own testing, initially i was running a 'reverse grind' 422 with 220int 215exh. this cam worked great. when i did a rebuild, i decided to go with one of the more common camshafts- the 422. the tuning for the engine did not change all that much. the volumetric efficiency shifted up slightly higher in the rpm band like 400 rpm. for idle, to get 14.5 a/f ratio, i had to reduce ve by about 2-3% in those cells. so, it really wasn't that big of a change.
i wouldnt worry about the cam too much. with a good set of heads, any of those three would be a good choice. they all have at least half an inch of lift, and they all have enough lobe seperation to work well with a turbo. i really see no bad choice among these three.
turbodig
Cam thoughts (Was:Help Picking Out a Camshaft)
I've been going over some research regarding turbo cams, and what I keep coming up with
is that a small negative overlap isn't far enough for a higher exhaust restriction turbo.
(Like the stocker or a 20 g)
A smaller housing turbo is going to have a TIP (turbine pressure) ratio of 2:1 or larger.
This means for 20 psi of inlet boost, you'll see 40 psi or more on the exhaust side.
The stock 8cm2 housing is probably even higher than that.
So, given that there's 40 psi in the exhaust manifold and ports, at the moment the
exhaust valve closes, there's 40 psi (maybe more) in the chamber.
If the intake opens before or at TDC, you have 20 psi trying to overcome 40 psi.
Not gonna happen.
Doing some fairly ugly math, it would take ~30-38 additional degrees of crank rotation
in order to pull enough suction on the pressurized cyl to get the overall pressure down
to under 20 psi. Opening the intake any earlier than that would be, in the best case
pointless, in the worst, detrimental. Opening earlier *will* cause the hot exhaust to
reverse into the intake, heating the ports/runners and corrupting the clean charge
with exhaust.
Now, this simplifies the system a bunch... there are effects of inertia on the air column,
as well as the the thermodynamics of it all. However, even really good tuned runner
manifold/header systems will struggle to make an effective pressure difference of 3 psi.
(And that's being generous) There's also leakage in the rings, etc.
The thermal effects are a bit harder to dismiss, since it's hard to know how much of
a drop in gas temp will happen in the cyl following the exhaust valve closing. This could
be as much as 4 or 5 psi (? WAG) depending on the amount of temp drop.
Subtracting both factors from the exhaust gets us down to about 32 psi vs. the 20
at the intake. Still too much pressure; air won't flow into this cylinder. It does allow the
intake timing to move back (advance) a few degrees.
This all depends greatly on the size of the turbo and particularly on the size of the
exhaust housing. Larger housings and more efficient header designs can lower that
TIP ratio down to 1.5 or less. The effects of the backpresure in these cases (ie, the
high-end, big dollar builds) diminishes rapidly, and the cam needs to look more like
a standard NA cam.
In the case of the stock system or milder turbos, though, the intake lobe appears to
need to be retarded a bunch. This has the effect of narrowing the duration down too,
and a shorter lobe makes getting full lift a lot harder. (A shorter duration will require
a steeper ramp to get the same lift; bad for valvetrain longevity)
This idea isn't really new; Vizard mentions it in one of his books, and there are references
to it in Haywood and Taylor if you read between the lines.
The later intake opening should allow a cooler, cleaner intake charge, and allow more
boost in the same application. It would also allow running a higher static CR (say,
9.5-9.8:1) without deto on street gas.
Just my thinkin' out loud...
Later,
