help tuning 63# injectors
whiteTy1214
I just got my new injectors installed. I got the 63# siemens, have a starter bin from Harmon. Having a hard time tring to figure out this f29x table. My afr all over the place.
To rich under boost and cold start up, sometimes setting check engine light and engine idle hunt. Other times to lean at idle in gear and during decel when driving.
I have read lots of info, but putting it to use in my tunerpro 4 does not seem to help me much. looked into a dyno tune place in salem, oregon, but they want 700 to 800 bucks.
I dont really have that at this time, so i parked the ty :rant:
Any one on one help would be really appreciated as i dont know what i am doing to be honest. thanks everyone for reading my post and advice if any. have a great day!
TurboTYPHOON
Re: help tuning 63# injectors
I am getting ready to do the same thing as you. While I have zero experience with $59 the only thing I can recommend is posting the same question on the $59 forum or googling the $59 starter power point slideshow.
You need to start off slow. Work on the idle first. Then work on part throttle. After that this working well move on to part throttle boost and the last thing is WOT.
Quickstop [UK]
Combating adversyty.
What cam have you got?
IN TP, use the emulate function to see where the cells are referencing from to get the fuel (the cells are highlighted in yellow - you need emulate selected and also the ALDL ink). They should remain in the same place give or take the odd flutter.
Depending on your cam, you'll want an idle AFR of 12 and up. I have a 415 and anything leaner than 13 and it gets really unhappy. from memory, that meant the cells were around 36 VE or so....
Make the values around the 4 cells roughly the same, so you have a box of 16 cells (1 cell in each direction).
You can then adjust the idle in steps of 5 VE in F29x first to get it in the ballpark and idling steadily. Once you're close, adjust using steps of 2 then 1.
The table will amend the values slightly so don't go chasing your tail.
Also, make sure you are not in closed loop - at idle this shouldn't be possible but double check.
What is your RPM set at?
If the value is too lean then the engine will bog and then jump to another cell value - don't keep adjusting those in the periphery.
Small steps....
Good luck.
Make a log of your idle using TP and perhaps someone can take a look.
whiteTy1214
thanks for your reply, stock cam and heads still.
I have highlighted the cell box and adjusted, not sure if for the better or worse, but got somewhere.
I have taken it to work a few times and it was unhappy. Mostly the idle hunt in gear, but would go away when put in park.
why does it change so much from idle park to idle in gear. thanks
wildphil
I Love My Ty's
You may want to add some fuel to the cells and adjoining cells that are being used in gear. My truck likes to idle around 14 or richer.
SY-1193
You will get idle hunt if your cells have too large of a jump from cell to cell. Try making the numbers you have in the area you are working on closer to each other numerically. Put the truck in gear with your foot on the brake and turn the steering wheel to lock if it stalls out you have work to do. Get it to where it will idle in gear with strain on it like the power steering pump can produce. Watch your AFR's. Have the realtime bubble going so you know what cells to work on. Work around that area of the bubble to get a good in gear idle. Then pop it into park and you may have to fine tune a little. Go on from there. It takes time. A good idle and in gear idle is definately where to start your tune because you don't want it stalling out every stop sign and red light when you go to on road tuning. Have a buddy drive and you tune from the passengers seat (safer). Good Luck. Pretty soon you will understand what is going on and it will hit you...bang. It will be like you can read the numbers on the screen like the Matrix...have some patience with yourself.
Save your new changes as a different .bin when you make some changes so you can always reload the last .bin that it ran with if you get it all messed up.
whiteTy1214
thanks for your replys. I am now tring a new bin. getting the f28 table tuned first. so far turned up 25%.
seems to idle good. now to move on to the f29x table and go from there.
