JayLo
Sir Boost-a-Lot
Ok,
I just uploaded these files. I'll keep reading up on the DataMaster program, but in the mean time, could you guys give me your thoughts on these three test runs.
Run 1
http://www.uploadtemple.com/view.php/1121134561.uni
Run 2
http://www.uploadtemple.com/view.php/1121134634.uni
Run3
http://www.uploadtemple.com/view.php/1121134676.uni
Run 3 is the longest and has many backfires/stumbles logged. At a quick glance, it appears my injector duty cylce goes through the roof (greater than 100%) even though I have a manual boost controller set to below 15psi. Base fuel pressure is set to 46psi with the vacuum fitting disconnected. What are your thoughts?
Thanks again for your help.
________
MatureDomme
Run 1
Run 2
Run3
________
MatureDomme
