Help with logged DataMaster data
JayLo
Sir Boost-a-Lot
Ok,
I just uploaded these files. I'll keep reading up on the DataMaster program, but in the mean time, could you guys give me your thoughts on these three test runs.
Run 1
http://www.uploadtemple.com/view.php/1121134561.uni
Run 2
http://www.uploadtemple.com/view.php/1121134634.uni
Run3
http://www.uploadtemple.com/view.php/1121134676.uni
Run 3 is the longest and has many backfires/stumbles logged. At a quick glance, it appears my injector duty cylce goes through the roof (greater than 100%) even though I have a manual boost controller set to below 15psi. Base fuel pressure is set to 46psi with the vacuum fitting disconnected. What are your thoughts?
Thanks again for your help.
________
MatureDomme
JayLo
Sir Boost-a-Lot
Re: Help with logged DataMaster data
Well, I exported run 3 to Excel and did some comparing, boost vs O2 voltage mainly. It appears I'm running VERY lean under boost most of the time. What do you guys think?
I just changed the fuel filter and fuel pressure regulator (adjustable) and have around 1/2 tank of gas. I would bet dollars to doughnuts I can create similar data with a full tank of gas.
Is my base fuel pressure (46psi w/o vacuum) too low?
Could I have a weak fuel pump that can't provide enough fuel pressure under high demand (boost) conditions?
________
Children depakote
sy538
If it is the stock fuel pump that is very likely, and I would replace it with a 255 immediately. Its kinda hard for me to tell exactly what’s going on, we usually look at full 1/4 mile wot runs, but you are making way too much knock even at 75% throttle.
See how much the fuel pump helps them go from there.
http://www.syty.net/forums/showthread.php?t=72
http://www.syty.net/forums/showthread.php?t=18752
Edit
Hotwire your IC pump also, and make sure it works. After you hotwire it will run whenever the key is on, even when the truck is not running.
http://www.sytyarchives.com/howto/viewarticle.php?article_name=ic_pump_hotwire.php&dir=engine
JayLo
Sir Boost-a-Lot
The IC pump already is hotwired. I had to replace the original pump and fuse as well.
Looks like I'll be ordering a Walbro sooner than I thought.
Does running that lean cause all the knock?
________
blonde girl Cam
sy538
Its hard for me to tell because you never go above 75% tps, and I'm used to looking at file where you go 100% tps and stay there for 13-14 seconds. Though I am NOT suggesting you do this, because you are making way too much knock already. Are you sure your IC pump is running? I have a hotwired Johnson pump with 3/4" lines and I never see IATs above 135* (except when EGR comes on). I don't know what to make of you O2mvs because you never went wot. I would lower boost as far as you can with the boost controller until you get a fuel pump in. It would be interesting to see what you truck runs like on 100 octane gas.
JayLo
Sir Boost-a-Lot
I have a Johnson pump hardwired with 3/4" lines. It runs. I can feel the flow in the hose and see it with the cap off.
135? seems much cooler than I would expect. My upper heat exchanger is still VERY hot to the touch, though not nearly as bad as it was when the pump wasn't functioning.
I'd didn't go WOT because the truck runs so poorly, but I did verify that the TPS reads WOT with the engine off.
I have bypassed the stock boost controller and am running a Grainger valve (manual boost controller).
________
BestOfBest4U cam
sy538
135º seems much cooler than I would expect. My upper heat exchanger is still VERY hot to the touch, though not nearly as bad as it was when the pump wasn't functioning.
something is very wrong with your IC system, when i said 135*, that was IAT at wot and at full boost. I can not get out of my truck fast enough to feel any heat in the upper IC.
I agree with that 100%, I just meant its hard for me to tell what I'm looking at cause I've never really looked at what my truck does at 75% tps. But I can tell you for sure that the IATs are much lower and it doesn't make any knock
I don't really know how those work, I just meant if you can turn boost down any more, then you should.
Edit
Oh, and for your other thread, BG said a 255 pump can get into the high 11s.
Also, someone put a smaller tank out of a base S-10 in their truck to help the fuel cutout at launch.
JayLo
Sir Boost-a-Lot
I?ll check for kinks in the hose. Is there something I can use to flush out the IC system, like a radiator cleaner? Even after moderate driving, mine is hot enough to burn fingers.
Did you have a hard time purging air from yours when you filled the system?
Have any others seen IAT temps as high as mine with a working and hardwired IC pump?
For a single boost level, even the fancy electronic boost controllers don?t work any better than a Grainger valve. Mine is only set to 12psi or so, but I will refrain from any further boosting until I get the fuel and IC temps in order.
Anyone else care to join the discussion?
________
Depakote Lawsuit
sy538
JayLo said:
I’ll check for kinks in the hose. Is there something I can use to flush out the IC system, like a radiator cleaner? Even after moderate driving, mine is hot enough to burn fingers.
Yeah I bet you have a kink somewhere. You can use RMI25, but I would only use about a tablespoon of it, the stuff works too good.
I can do a 0-100mph run at wot, get on the brakes fairly hard, get out and put my hand on the upper IC and it feels about the same as the hood or fender.
Yes, a very hard time. But my hoses are not routed the right way, my pump is pushing water into the upper IC instead of pulling water out of it, so I cant take the cap off while the pump is running of water will run out. I have clear lines to help with the air, but with your temps I wouldn’t recommend that.
edit
Maybe I’m wrong, but I get the feeling that you don’t know that you can change the graph to show whatever you want. Just double click on any of the 4 graph description boxes on the right.
Jimmy
Banned
I tried to look at it,but it's too ****ed up to tell anything.One thing is certain,your IAT's are stupid hot.
I see your TCC locking at 60 mph.You got a switch or a custom chip doing that?
I'd put a new 160 stat in it too.It's running 190.
I've never seen 182 degrees IAT's :shocked!:
JayLo
Sir Boost-a-Lot
Its the stock chip, as far as I know. And my 160? stat (from Detroit Turbo) is less than a month old.
________
LIVE SEX WEBSHOWS
JayLo
Sir Boost-a-Lot
Where do I pick up RMI-25? Napa, O'Reilly's?
I figured with a 160? stat it would still get 20 or so degrees above the stat opening point when the vehicle is running. Maybe I need to flush the radiator as well as the water-side IC system.
At what speed is the TCC supposed to lock up? Do these trucks normally slam second gear pretty hard under part throttle?
________
SquirtBOOM
Tooky
Serious about performance
How hot is it outside by you, JayLo? I have a 160 "RobertShaw Gold" autozone Tstat and it keeps my temps right at 159-161 the majority of the time. When it is hot out or I'm beating on the truck 1/4mi it will go to 169*F. The only time it goes past 169 is when it is deadly hot out (85*F+) or if I have the A/C operating. I would flush your radiator (especially if you have never done it). If it's really rusty & shitty, Prestone sells stuff like Super Radiator Flush that has directions on how to use it (requires some heat/driving cycles etc.).
Your upper IC should not be anywhere near "hot enough to burn fingers". Do you have an exhaust leak that's blasting hot exhaust on it or something? That's pretty extreme. If you run your pump while the IC cap is off, can you see the coolant flowing/stirring at all?
The stock chip locks TCC at about 70MPH at WOT but will be proportionally less with less TPS%, therefore if JayLo wasn't 100% TPS his WOT TCC Lock may be at a lower MPH.. I haven't seen the Datamaster file yet but what I said is logical.
Running lean could easily cause all that knock, especially if your pump isn't keeping up. You might be one of those guys who replaces his factory fuel pump with a Walbro and comes back to the board saying "I can't beleive how much faster my truck is now!!!" I've seen it happen before. If you have access to a fuel pressure gauge you could tape it to the windshield and watch it while you're driving. (I had to take off the hood to do it on mine, only requires 2 men and 4 bolts...) Then you would be able to verify pretty certainly whether or not the pump is dropping pressure at WOT.
JayLo
Sir Boost-a-Lot
I was running the A/C and it was pretty warm (humid, mostly) during those runs. I'll pickup some radiator flush stuff tonight and run it in both systems.
The intercooler system has some grey sludge, almost looks like Bars Stop Leak. I'll clean it up and see if it starts leaking. I have pulled the cap off and I see plenty of movement so I'm positive my pump is functioning correctly.
The under hood temps are outrageous, or so they seem. Maybe this is why my IC gets so hot.
Thanks for to continued help, fellas. I sure hope I'm one of those "holy Jeez, that fuel pump made a huge difference!" guys. I wanted a 13 second truck, not a low mile slug.
Do any of you guys experience some smoking on startup after the truck has sat for a day or more? I assume it's the valve guides. It's really odd to me that it would smoke when cold with so few miles. Judging from his old Jags, his age and his demeanor, I seriously doubt the previous owner beat the truck.
________
2BigHardCock2CUM
sy538
This is not cool at all. Have you replaced the stock metal lines with 3/4” heater hose yet? If not, now is the time to do it. Remove the whole IC system and hook up a water hose to the upper IC. Run water through it until it comes out completely clean. Do the same thing with the lower IC. Put it back together with the heater hose. Get about 20 feet. Make sure the pump pulls water from the upper IC and pushes into the lower. USE DISTILLED WATER and antifreeze, with a very small amount of RMI25. I would recommend clear hose from the upper IC to the fender, but not with the temps you are seeing. I did this about 2 years ago and the coolant is as clean as the day I poured it in. Whenever I get around to adding an auxiliary cooler I will fix it so the pump is pulling out of the upper (will make it easier to get the air out), but since I’m running stock boost for now, there is no need yet. The stock system with a good pump that is hotwired is plenty for stock boost levels.
http://www.syty.net/forums/showthread.php?t=29166
http://www.sytyarchives.com/howto/viewarticle.php?article_name=ic_hose_and_pump.php&dir=engine
Tooky
Hey I got a chance to look at your Datamaster file you emailed me, that thing is lean as hell. Your Long Term and Short Term (especially) fuel trims are freaking out. I bet your plugs look scary lean.
Have you ever changed your fuel filter? If not they cost about $8 from GM and take less than 30 minutes to change, assuming your truck wasn't driven heavily through winter or anything (rusted lines).. I mean your truck looks so lean I wouldnt be surprised if your fuel filter was damn near clogged.
I really think you're going to be surprised at the results when you alleviate this fuel delivery problem.. I can see it already, man!! :cool: :rock:
JayLo
Sir Boost-a-Lot
You guys were right on the money with regard to my pump being tired. First trip out with the Racetronix fuel pump, and it's a night and day difference. Now when I stab the throttle, it just goes and goes... no cutting out, no stumbling, just endless torque.
I hooked the Datamaster to it (I'll post the file in a new thread later) and I'm actually getting an O2 too rich error code under boost.
O2 millivolts are above 900 when I see 5psi or more of sustained boost (I'm set at 14.8psi right now). Base fuel pressure is 46psi with no vacuum to the AFPR. I'll drop the pressure some when I get the wideband installed.
It feels like a low 14 second truck as it runs today which is a huge improvement.
My next challenge will be fixing the knock. Above 7psi it picks up lots of knock (none that I can hear) and pulls all of the timing. Any suggestions?
When the fuel level gets lower, I'm going to add several gallons of 100 octance unleaded and see if it still picks up knock. I suppose if it does, should I look at replacing the knock sensor(s). Are there sensors for each head?
Thanks again for all of your help. :tup:
Regards,
________
Park Royal 2 Condo
sy538
If you haven’t got your IATs down any then I would bet that is the reason you still have knock.
