Help with PCM grounds
JayLo
Sir Boost-a-Lot
Most have probably forgotten about it by now, but we?re still working on the MegaSquirt (albeit very little). I?ve been sidetracked the last month helping a buddy get his 5.Slow running. But I?m back on the truck now.
We have encountered some major issues with the TPS sensor. Specifically we?re seeing noise on the line (even with the truck not running but keyed on). This causes faulty accel enrichments at idle (TPS need bounces a couple of % even if my foot is off the gas).
MegaSquirt allows changing the TPS-based Accel enrichment threshold (volts per second), but anything higher (which fixes the idle problem) causes a lean (and corresponding flat) spot on throttle tip-in.
We have checked everything on the MS side of the install and now believe that the PCM (still being used for IAC and anything else it does other than fuel and spark) is causing the TPS line noise.
I told Scott about the PCM ground problems I?ve read about on here that our trucks sometimes suffer from.
My question is, what ground wires on the PCM tend to have issues?
If possible, the general locations of these wires would be helpful too.
Thanks.
________
Lientte1
JayLo
Sir Boost-a-Lot
Re: Help with PCM grounds
VermontTy said:
Are you talking the stock ECM Justin?
That is correct.
I'd like to know which grounds seem to be the most problematic and where they are located.
________
Live Sex Webshows
VermontTy
Support Our Troops
There is a chassis ground for the ECM that attach (in stock dress) to the intake manifold stud behind the alternator. 551, tan / black. For the TPS, all 3 wires run back to the ECM. 155 black is shared by the TPS and MAT sensor, and 416 gray & 417 dark blue also run back to the ECM.
For the TPS, 5V is fed on the gray wire, the signal is fed back on the dark blue wire, and ground is provided by the black wire. I made a mental note of this for some reason this winter, the dark blue wire is the smallest gauge wire I ran across in the whole engine harness. It could just have been me, but it seemed VERY small. I'd first check the ECM chassis ground, then check the ground strap on the back of the drivers head, then verify that with the key on you have 5V on gray. It might not hurt to run a larger gauge dark blue wire to reduce voltage drop back to the ECM and see where that gets you.
EDIT - I've got a bunch of wiring crap in the gallery below you can thumb through too.
http://www.northeastsyty.com/gallery/view_album.php?set_albumName=album442&page=1
leroy
The TPS is grounded on B5 on the ecm. Sensors are grounded to the ecm to prevent noise. I'm not sure how yours is hooked up. Does megasquirt provide a sensor ground?
Jim
