JayLo
Sir Boost-a-Lot
Most have probably forgotten about it by now, but we?re still working on the MegaSquirt (albeit very little). I?ve been sidetracked the last month helping a buddy get his 5.Slow running. But I?m back on the truck now.
We have encountered some major issues with the TPS sensor. Specifically we?re seeing noise on the line (even with the truck not running but keyed on). This causes faulty accel enrichments at idle (TPS need bounces a couple of % even if my foot is off the gas).
MegaSquirt allows changing the TPS-based Accel enrichment threshold (volts per second), but anything higher (which fixes the idle problem) causes a lean (and corresponding flat) spot on throttle tip-in.
We have checked everything on the MS side of the install and now believe that the PCM (still being used for IAC and anything else it does other than fuel and spark) is causing the TPS line noise.
I told Scott about the PCM ground problems I?ve read about on here that our trucks sometimes suffer from.
My question is, what ground wires on the PCM tend to have issues?
If possible, the general locations of these wires would be helpful too.
Thanks.
________
Lientte1
Thanks.
________
Lientte1
