help with speedpro
FLSY2730
In the timing setup, am i suppose to set the btdc to 0 degrees , when i use the timing light i got 34 degrees with the balancer at zeroso am i to put 34 degrees in the set up parameters? please help jack
RAACCR
Speedpro will not allow you to enter a reference angle of zero, so you really need to manually set the distributor initial advance at least 1 degree btdc to sync up perfectly.
Here's what I do: 1) get a dial adjustable timing light. 2) watch the timing indication on the Speedpro dashboard (NOT on the target timing map grid, because that will not account for any adjustments the Speedpro is making to your target value). 3) Adjust the reference angle in Speedpro until the dashboard timing value matches the timing light.
I'm off work 'til after New Year. Give me a call at home (561) 276-9665, or on my cell (561) 901-0440, and I can try to talk you through the process.
FLSY2730
thanks rob, i could def. use your help to dial this truck in , i have it running for the first time in a while now i changed the cam, went a little bigger and got the speedpro and 72 turbo from mike at ar and now its running for the first time with the speedpro, seems a little rough at idle and a little smoother above 2300. i wish i could load a program for this combo and be done anyway i would def. apprciate your help jack
