Speedpro will not allow you to enter a reference angle of zero, so you really need to manually set the distributor initial advance at least 1 degree btdc to sync up perfectly.
Here's what I do: 1) get a dial adjustable timing light. 2) watch the timing indication on the Speedpro dashboard (NOT on the target timing map grid, because that will not account for any adjustments the Speedpro is making to your target value). 3) Adjust the reference angle in Speedpro until the dashboard timing value matches the timing light.
I'm off work 'til after New Year. Give me a call at home (561) 276-9665, or on my cell (561) 901-0440, and I can try to talk you through the process.
