Re: help with tuner pro
Hi Dave,
With the truck started, or key on, launch TunerPro.
Hit the F4 button. At the bottom of the screen that comes up will be a little box that says "connect". Click on that box. You should now see data streaming from the ECM into TunerPro.
At the top right of the screen is a series of buttons that look like those on a cassette deck. The Red Circle is the record button. Click on that and a box at the bottom of the screen will turn green and you will be recording. When you're ready to stop recording, hit the square box at the upper right of the screen - a box will pop up asking you for a comment for that recording session - I usually put in the date and time. Hit save, and you're done.
If you want to play it back, push the F4 button again and click on the pull down menu that denotes the time of the recording session, and click on the newest entry. Then you can click on the play button and your data will start playing. You can click on the 'v', 'd', 'm' buttons at the top of the main screen to bring up different modes of viewing the data.
Hope this helps,
Rob
